MBR4035PT – MBR40200PT
Taiwan Semiconductor
40A, 35V - 200V Schottky Barrier Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Low power loss, high efficiency
Guard ring for overvoltage protection
High surge current capability
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
40
A
VRRM
35 - 200
V
IFSM
330
A
TJ MAX
150
°C
Package
TO-247AD (TO-3P)
Configuration
Dual dies
Switching mode power supply (SMPS)
Adapters
Monitor
DC to DC converters
TV
MECHANICAL DATA
Case: TO-247AD (TO-3P)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Mounting torque: 1.13 N⋅m maximum
Polarity: As marked
Weight: 6.10g (approximately)
TO-247AD (TO-3P)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on the device
Repetitive peak reverse
voltage
Reverse voltage, total rms
value
Forward current
Surge peak forward current
8.3ms single half sine wave
superimposed on rated load
Peak repetitive reverse surge
(1)
current
Peak repetitive forward
current (Rated VR, Square
wave, 20KHz)
Notes:
1. tp = 2.0μs, 1.0KHz
MBR
SYMBOL 4035
PT
MBR
4035
PT
MBR
4045
PT
MBR
4045
PT
MBR
4050
PT
MBR
4050
PT
MBR
4060
PT
MBR
4060
PT
MBR MBR MBR MBR
4090 40100 40150 40200 UNIT
PT
PT
PT
PT
MBR MBR MBR MBR
PT
PT
PT
PT
VRRM
35
45
50
60
90
100
150
200
V
VR(RMS)
24
31
35
42
63
70
105
140
V
IF
40
A
IFSM
330
A
IRRM
2
1
IFRM
40
1
A
A
Version: I2103
MBR MBR MBR MBR MBR MBR MBR MBR
SYMBOL 4035 4045 4050 4060 4090 40100 40150 40200 UNIT
PT
PT
PT
PT
PT
PT
PT
PT
PARAMETER
Critical rate of rise of off-state
voltage
Junction temperature
Storage temperature
dV/dt
10,000
V/μs
TJ
-55 to +150
°C
TSTG
-55 to +150
°C
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
1.2
°C/W
Junction-to-case thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
MBR4035PT
MBR4045PT
MBR4050PT
MBR4060PT
MBR4090PT IF = 20A, TJ = 25°C
MBR40100PT
SYMBOL
MBR40150PT
MBR40200PT
MBR4035PT
MBR4045PT
MBR4050PT
MBR4060PT
MBR4090PT IF = 40A, TJ = 25°C
MBR40100PT
MBR40150PT
MBR40200PT
Forward voltage per diode
(1)
MBR4035PT
MBR4045PT
MBR4050PT
MBR4060PT
MBR4090PT IF = 20A, TJ = 125°C
MBR40100PT
MBR40150PT
MBR40200PT
MBR4035PT
MBR4045PT
MBR4050PT
MBR4060PT
MBR4090PT IF = 40A, TJ = 125°C
MBR40100PT
MBR40150PT
MBR40200PT
TYP
MAX
UNIT
0.75
V
0.77
V
0.84
V
0.90
V
0.80
V
V
V
1.01
V
0.65
V
0.67
V
0.74
V
0.80
V
0.75
V
V
V
V
VF
Notes:
1. Pulse test with PW = 0.3ms
2
Version: I2103
PARAMETER
Reverse current @ rated VR
(2)
per diode
CONDITIONS
MBR4035PT
MBR4045PT
MBR4050PT
MBR4060PT
TJ = 25°C
MBR4090PT
MBR40100PT
MBR40150PT
MBR40200PT
MBR4035PT
MBR4045PT
MBR4050PT
MBR4060PT
TJ = 125°C
MBR4090PT
MBR40100PT
MBR40150PT
MBR40200PT
SYMBOL
TYP
MAX
UNIT
1000
µA
500
µA
100
µA
30
mA
mA
10
mA
IR
Notes:
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
MBR40xPT
TO-247AD (TO-3P)
30 / Tube
MBR40xPTH
TO-247AD (TO-3P)
30 / Tube
Notes:
1. “x” defines voltage from 35V(MBR4035PT) to 200V(MBR40200PT)
2. “H” means AEC-Q101 qualified
3
Version: I2103
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
4035PT - 4045PT
4050PT - 4060PT
4090PT - 40200PT
40
35
CAPACITANCE (pF)
30
25
1000
10
f=1.0MHz
Vsig=50mVp-p
5
100
50
75
100
125
0.1
150
1
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
4035PT - 4045PT
4050PT - 40200PT
TJ=125°C
TJ=75°C
1
0.1
TJ=25°C
0.01
0.001
10
40
50
60
70
80
90
100
100010
100 1
4035PT - 4045PT
4050PT - 4060PT
4090PT
- 40200PT
UF1DLW
TJ=125°C
TJ=125°C
10
0.1
TJ=25°C
1
0.01
TJ=25°C
0.1
0.001
0.0
0.3
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Pulse width 300μs
1% duty cycle
Pulse width
0.2
0.4
0.4
0.5
0.6
0.8
0.6
0.7
0.8
1.0
0.9
1.2
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
360
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
1000
10
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
100
10
330
300
270
240
210
180
150
120
90
60
30
10
100
NUMBER OF CYCLES AT 60 Hz
4
(A)
AVERAGE FORWARD CURRENT (A)
45
Version: I2103
1.2
Fig.6 Typical Transient Thermal Impedance
TRANSIENT THERMAL IMPEDANCE (°C/W)
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
5
Version: I2103
PACKAGE OUTLINE DIMENSIONS
TO-247AD (TO-3P)
MARKING DIAGRAM
6
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: I2103
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: I2103
很抱歉,暂时无法提供与“MBR4050PT C0G”相匹配的价格&库存,您可以联系我们找货
