MBRS1035CT – MBRS10150CT
Taiwan Semiconductor
10A, 35V - 150V Schottky Barrier Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Low power loss, high efficiency
Ideal for automated placement
Guard ring for overvoltage protection
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
10
A
VRRM
35 - 150
V
IFSM
120
A
TJ MAX
150
APPLICATIONS
°C
2
Package
TO-263AB (D PAK)
Configuration
Dual dies
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converters
MECHANICAL DATA
2
Case: TO-263AB (D PAK)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.37g (approximately)
2
TO-263AB (D PAK)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on the device
Repetitive peak reverse
voltage
Reverse voltage, total rms
value
Forward current
Surge peak forward current,
8.3ms single half sine wave
superimposed on rated load
Peak repetitive reverse
(1)
surge current
Peak repetitive forward
current (Rated VR, Square
wave, 20KHz)
Critical rate of rise of offstate voltage
Notes:
1. tp = 2.0μs, 1.0KHz
MBRS
SYMBOL 1035
CT
MBRS
1035CT
MBRS
1045
CT
MBRS
1045CT
MBRS
1050
CT
MBRS
1050CT
MBRS
1060
CT
MBRS
1060CT
MBRS MBRS MBRS
1090 10100 10150 UNIT
CT
CT
CT
MBRS MBRS
MBRS
1090CT 10100CT 10150CT
VRRM
35
45
50
60
90
100
150
V
VR(RMS)
24
31
35
42
63
70
105
V
IF
10
A
IFSM
120
A
IRRM
1
A
IFRM
10
A
dv/dt
10,000
V/μs
1
Version: M2103
MBRS MBRS MBRS MBRS MBRS MBRS
SYMBOL 1035 1045 1050 1060 1090 10100
CT
CT
CT
CT
CT
CT
PARAMETER
MBRS
10150 UNIT
CT
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
2
°C/W
Junction-to-case thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage per diode
CONDITIONS
(1)
MBRS1035CT
MBRS1045CT
MBRS1050CT
MBRS1060CT
MBRS1090CT
MBRS10100CT
MBRS10150CT
MBRS1035CT
MBRS1045CT
MBRS1050CT
MBRS1060CT
MBRS1090CT
MBRS10100CT
MBRS10150CT
MBRS1035CT
MBRS1045CT
MBRS1050CT
MBRS1060CT
MBRS1090CT
MBRS10100CT
MBRS10150CT
MBRS1035CT
MBRS1045CT
MBRS1050CT
MBRS1060CT
MBRS1090CT
MBRS10100CT
MBRS10150CT
SYMBOL
IF = 5A, TJ = 25°C
IF = 10A, TJ = 25°C
VF
IF = 5A, TJ = 125°C
IF = 10A, TJ = 125°C
2
TYP
MAX
UNIT
0.70
V
0.80
V
0.85
V
0.88
V
0.80
V
0.90
V
0.95
V
0.98
V
0.57
V
0.65
V
0.75
V
0.78
V
0.67
V
0.75
V
0.85
V
0.88
V
Version: M2103
PARAMETER
Reverse current @ rated VR
(2)
per diode
CONDITIONS
MBRS1035CT
MBRS1045CT
MBRS1050CT
MBRS1060CT TJ = 25°C
MBRS1090CT
MBRS10100CT
MBRS10150CT
MBRS1035CT
MBRS1045CT
MBRS1050CT
MBRS1060CT TJ = 100°C
MBRS1090CT
MBRS10100CT
MBRS10150CT
MBRS1035CT
MBRS1045CT
MBRS1050CT
MBRS1060CT TJ = 125°C
MBRS1090CT
MBRS10100CT
MBRS10150CT
SYMBOL
IR
TYP
MAX
UNIT
100
µA
15
mA
10
mA
mA
mA
5
mA
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
MBRS10xCT
PACKAGE
2
TO-263AB (D PAK)
PACKING
800 / Tape & Reel
Notes:
1. “x” defines voltage from 35V(MBRS1035CT) to 150V(MBRS10150CT)
3
Version: M2103
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
900
800
CAPACITANCE (pF)
10
5
700
600
500
400
300
200
f=1.0MHz
Vsig=50mVp-p
100
50
75
100
125
150
0.1
1
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
TJ=75°C
0.1
0.01
TJ=25°C
0.001
10
40
50
60
70
80
90
100
100 10
MBRS1035CT - 1045CT
10
MBRS1050CT - 1060CT
UF1DLW
1
MBRS1090CT - 10100CT
TJ=125°C
TJ=25°C
0.1
1
MBRS10150CT
0.01
Pulse width 300μs
1% duty cycle
Pulse width
0.1
0.001
0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
150
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
100
1
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
10
10
(A)
AVERAGE FORWARD CURRENT (A)
15
120
90
60
30
10
100
NUMBER OF CYCLES AT 60 Hz
4
Version: M2103
1.2
Fig.6 Typical Transient Thermal Impedance
TRANSIENT THERMAL IMPEDANCE (°C/W)
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
5
Version: M2103
PACKAGE OUTLINE DIMENSIONS
2
TO-263AB (D PAK)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
6
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: M2103
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: M2103
很抱歉,暂时无法提供与“MBRS10100CTHMNG”相匹配的价格&库存,您可以联系我们找货
