BAT54CD REG
BAT54CD REG
    TAIWANSEMICONDUCTOR(台湾半导体)
    TSSOP-6
    DIODE ARRAY SCHOTTKY 30V SOT363
BAT54CD REG 数据手册
BAT54T/AD/CD/SD/BR Taiwan Semiconductor 200mA, 30V Schottky Barrier Diode FEATURES ● ● ● ● ● ● KEY PARAMETERS Fast switching speed Low forward voltage drop Surface mount device type Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 200 mA VRRM 30 V IFSM 600 mA VF at IF = 100mA 1 V TJ MAX 150 °C Package ● Voltage clamping ● Reverse polarity protection ● High speed switching SOT-363 MECHANICAL DATA ● ● ● ● ● Case: SOT-363 Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 1A whisker test Weight: 6.99mg (approximately) PIN CONFIGURATION BAT54T BAT54AD BAT54CD BAT54SD BAT54BR ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device Power dissipation BAT54 T BAT54 AD BAT54 CD BAT54 SD KLA KL6 KL7 KL8 BAT54 UNIT BR KLB PD 200 mW Repetitive peak reverse voltage VRRM 30 V Repetitive peak forward current IFRM 300 mA Forward current Non-Repetitive peak forward surge current @ t < 1.0s Junction temperature range IF 200 mA IFSM 600 mA TJ -65 to +150 °C Storage temperature range TSTG -65 to +150 °C 1 Version: H2111 BAT54T/AD/CD/SD/BR Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJA 625 °C/W Junction-to-ambient thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage per diode CONDITIONS (1) Reverse voltage Reverse current @ rated VR per diode (2) Junction capacitance Reverse recovery time SYMBOL MIN MAX UNIT IF = 0.1mA, TJ = 25°C - 0.24 V IF = 1mA, TJ = 25°C - 0.32 V - 0.40 V IF = 30mA, TJ = 25°C - 0.50 V IF = 100mA, TJ = 25°C - 1.00 V IF = 10mA, TJ = 25°C VF IR = 100μA, TJ = 25°C VR 30 - V VR = 25 V, TJ = 25°C IR - 2 μA 1MHz, VR = 1V CT - 10 pF trr - 5 ns IF = IR = 10mA , RL = 100Ω , IRR = 1mA Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE PACKAGE PACKING BAT54T RFG SOT-363 3K / 7" Reel BAT54AD RFG SOT-363 3K / 7" Reel BAT54CD RFG SOT-363 3K / 7" Reel BAT54SD RFG SOT-363 3K / 7" Reel BAT54BR RFG SOT-363 3K / 7" Reel 2 Version: H2111 BAT54T/AD/CD/SD/BR Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Typical Forward Characteristics Fig.2 Typical Reverse Characteristics IR, Instantaneous Reverse Current (μA) IF, Instantaneous Forward Current (A) 1000 100 TA=125°C 10 TA=75°C TA=25°C 1 TA=0°C TA= -40°C 0.1 0.0 0.2 0.4 0.6 0.8 100 TA=125°C 10 TA=75°C 1 TA=25°C 0.1 TA=0°C 0.01 0.001 0 1.0 VF, Instantaneous Forward Voltage (V) 10 20 30 VR, Instantaneous Reverse Voltage (V) Fig.3 Capacitance Between Terminals Characteristics Fig.4 Power Derating Curve 10 200 PD, Power Dissipation (mW) CT, Capacitance Between Terminals (pF) 12 8 6 4 2 100 0 0 0 5 10 15 20 25 0 30 25 50 75 100 125 150 TA, Ambient Temperature (°C) VR, Reverse Voltage (V) 3 Version: H2111 BAT54T/AD/CD/SD/BR Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS SOT-363 SUGGESTED PAD LAYOUT Notes: This recommended land pattern is for reference purposes only. Please consult your manufacturing group to ensure your PCB design guidelines are met. MARKING DIAGRAM KLx = Marking Code 4 Version: H2111 BAT54T/AD/CD/SD/BR Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: H2111
BAT54CD REG 价格&库存
很抱歉,暂时无法提供与“BAT54CD REG”相匹配的价格&库存,您可以联系我们找货
