2A07G A0G
2A07G A0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-204AC
    DIODE GEN PURP 2A DO204AC
2A07G A0G 数据手册
2A01G – 2A07G Taiwan Semiconductor 2A, 50V - 1000V Standard Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Glass passivated chip junction High efficiency, Low VF High current capability High surge current capability Low power loss RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 2 A VRRM 50 - 1000 V IFSM 70 A TJ MAX 150 °C Package DO-204AC (DO-15) Configuration Single die APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● General purpose MECHANICAL DATA ● ● ● ● ● ● Case: DO-204AC (DO-15) Molding compound meets UL 94V-0 flammability rating Terminal: Pure tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.400g (approximately) DO-204AC (DO-15) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL 2A01G 2A02G 2A03G 2A04G 2A05G 2A06G 2A07G UNIT Marking code on the 2A01G 2A02G 2A03G 2A04G 2A05G 2A06G 2A07G device Repetitive peak reverse VRRM 50 100 200 400 600 800 1000 V voltage Reverse voltage, total rms VR(RMS) 35 70 140 280 420 560 700 V value Forward current IF 2 A Surge peak forward current, 8.3ms single half IFSM 70 A sine wave superimposed on rated load Junction temperature TJ -55 to +150 °C Storage temperature TSTG -55 to +150 1 °C Version: I2105 2A01G – 2A07G Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 25 °C/W Junction-to-ambient thermal resistance RӨJA 60 °C/W Junction-to-case thermal resistance RӨJC 22 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS 2A01G 2A02G 2A03G 2A04G 2A05G 2A06G 2A07G (1) Reverse current @ rated VR (2) Junction capacitance IF = 2A, TJ = 25°C TJ = 25°C SYMBOL 1MHz, VR = 4.0V MAX UNIT - 1.1 V - 1.0 V - 5 µA - 100 µA 15 - pF VF IR TJ = 125°C TYP CJ Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING 2A0xG DO-204AC (DO-15) 3,500 / Tape & Reel 2A0xG A0G DO-204AC (DO-15) 1,500 / Ammo box 2A0xGH DO-204AC (DO-15) 3,500 / Tape & Reel 2A0xGHA0G DO-204AC (DO-15) 1,500 / Ammo box Notes: 1. "x" defines voltage from 50V (2A01G) to 1000V (2A07G) 2. “H” means AEC-Q101 qualified 2 Version: I2105 2A01G – 2A07G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 CAPACITANCE (pF) 2 1 10 f=1.0MHz Vsig=50mVp-p 1 0 25 50 75 100 125 0.1 150 1 AMBIENT TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C TJ=75°C 0.1 TJ=25°C 0.01 10 20 30 40 50 60 70 80 90 100 1010 UF1DLW 1 2A01G-2A02G TJ=125°C TJ=25°C 10.1 2A03G-2A07G 0.01 0.1 0.001 0.60.3 0.7 0.4 0.8 0.5 Pulse Pulse width width 300μs 300μs 1% duty cycle Pulse width 0.9 0.6 1 0.7 1.1 0.8 1.2 0.9 11.3 1.1 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig.5 Maximum Non-Repetitive Forward Surge Current 80 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (µA) Fig.4 Typical Forward Characteristics 100 1 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 (A) AVERAGE FORWARD CURRENT (A) 3 70 8.3ms single half sine wave 60 50 40 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: I2105 1.2 2A01G – 2A07G Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-204AC (DO-15) MARKING DIAGRAM 4 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: I2105 2A01G – 2A07G Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: I2105
2A07G A0G 价格&库存
很抱歉,暂时无法提供与“2A07G A0G”相匹配的价格&库存,您可以联系我们找货
