HERAF1001G – HERAF1008G
Taiwan Semiconductor
10A, 50V - 1000V High Efficient Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Glass passivated chip junction
High efficiency, Low VF
High current capability
High reliability
High surge current capability
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
10
A
VRRM
50 - 1000
V
IFSM
150
A
TJ MAX
150
°C
Package
ITO-220AC
Configuration
Single die
APPLICATIONS
● DC to DC converter
● Switching mode converters and inverters
● Freewheeling application
MECHANICAL DATA
Case: ITO-220AC
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.70g (approximately)
ITO-220AC
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on
the device
Repetitive peak
reverse voltage
Reverse voltage,
total rms value
Forward current
Surge peak
forward current,
8.3ms single half
sine wave
superimposed on
rated load
Junction
temperature
Storage
temperature
HERAF
1001G
HERAF
1001G
HERAF
1002G
HERAF
1002G
HERAF
1003G
HERAF
1003G
HERAF
1004G
HERAF
1004G
HERAF
1005G
HERAF
1005G
HERAF
1006G
HERAF
1006G
HERAF
1007G
HERAF
1007G
VRRM
50
100
200
300
400
600
800
1000
V
VR(RMS)
35
70
140
210
280
420
560
700
V
SYMBOL
HERAF
UNIT
1008G
HERAF
1008G
IF
10
A
IFSM
150
A
TJ
-55 to +150
°C
TSTG
-55 to +150
°C
1
Version: I2105
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
2
°C/W
Junction-to-case resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
(1)
Reverse current @ rated VR
Junction capacitance
Reverse recovery time
CONDITIONS
HERAF1001G
HERAF1002G
HERAF1003G
HERAF1004G
I = 10A, TJ = 25°C
HERAF1005G F
HERAF1006G
HERAF1007G
HERAF1008G
TJ = 25°C
(2)
SYMBOL
TJ = 125°C
HERAF1001G
HERAF1002G
HERAF1003G
HERAF1004G
1MHz, VR = 4.0V
HERAF1005G
HERAF1006G
HERAF1007G
HERAF1008G
HERAF1001G
HERAF1002G
HERAF1003G
HERAF1004G IF = 0.5A, IR = 1.0A
HERAF1005G Irr = 0.25A
HERAF1006G
HERAF1007G
HERAF1008G
VF
IR
TYP
MAX
UNIT
1.0
V
1.3
V
1.7
V
10
µA
400
µA
80
pF
60
pF
50
ns
80
ns
CJ
trr
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
HERAF10xG
ITO-220AC
50 / Tube
HERAF10xGH
ITO-220AC
50 / Tube
Notes:
1. “x” defines voltage from 50V(HERAF1001G) to 1000V(HERAF1008G)
2. “H” means AEC-Q101 qualified
2
Version: I2105
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
10
CAPACITANCE (pF)
8
6
4
HERAF1001G-1005G
100
HERAF1006G-1008G
10
2
f=1.0MHz
Vsig=50mVp-p
1
50
75
100
125
1
150
10
CASE TEMPERATURE (°C)
REVERSE VOLTAGE (V)
Fig.4 Typical Forward Characteristics
INSTANTANEOUS FORWARD CURRENT (A)
1000
TJ=125°C
100
10
TJ=25°C
1
40
50
60
70
80
90
100
100 10
1
HERAF1001G-1004G
UF1DLW
10
TJ=125°C
TJ=25°C
0.1
HERAF1005G
1
0.01
HERAF1006G-1008G
0.001
0.1
0.5
0.40.3 0.60.4 0.8
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Pulse
width
Pulse width
300μs
1% duty cycle
0.6
1
0.7
1.2
0.8
1.4
0.9
1.6
11.8 1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
180
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.3 Typical Reverse Characteristics
10
100
(A)
AVERAGE FORWARD CURRENT (A)
12
150
120
90
60
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: I2105
1.2
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: I2105
PACKAGE OUTLINE DIMENSIONS
ITO-220AC
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: I2105
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: I2105
很抱歉,暂时无法提供与“HERAF1001G C0G”相匹配的价格&库存,您可以联系我们找货
