SBS34 – SBS36
Taiwan Semiconductor
3A, 40V - 60V Schottky Bridge Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Schottky technology
Ideal for automated placement
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
3
A
VRRM
40 - 60
V
IFSM
80
A
TJ MAX
125, 150
°C
APPLICATIONS
Package
ABS
Configuration
Quad
● Charging circuit
● Power over Ethernet
● Lighting application
MECHANICAL DATA
Case: ABS
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 0.090g (approximately)
ABS
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
SBS34
SBS36
SBS34
SBS36
UNIT
Repetitive peak reverse voltage
VRRM
40
60
V
Reverse voltage, total rms value
VR(RMS)
28
42
V
Forward current
Peak forward surge current, 8.3ms single
half sine-wave superimposed on rated load
Rating for fusing (t
很抱歉,暂时无法提供与“SBS36 REG”相匹配的价格&库存,您可以联系我们找货
