ABS2 – ABS10
Taiwan Semiconductor
1A, 200V- 1000V Standard Bridge Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Glass passivated chip junction
Ideal for automated placement
Reliable low cost construction utilizing molded plastic technique
High surge current capability
UL Recognized File # E-326854
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
1
A
VRRM
200 - 1000
V
IFSM
30
A
TJ MAX
150
°C
Package
ABS
Configuration
Quad
APPLICATIONS
● Switching mode power supply (SMPS)
● Adapters
● Lighting application
MECHANICAL DATA
Case: ABS
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 0.120g (approximately)
ABS
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
ABS2
ABS4
ABS6
ABS8 ABS10 UNIT
ABS2
ABS4
ABS6
ABS8
ABS10
Repetitive peak reverse voltage
VRRM
200
400
600
800
1000
V
Reverse voltage, total rms value
VR(RMS)
140
280
420
560
700
V
0.8
A
1.0
A
IFSM
30
A
It
2
3.74
As
Junction temperature
TJ
- 55 to +150
°C
Storage temperature
TSTG
- 55 to +150
°C
Forward current
On glass-epoxy
On aluminum substrate
Peak forward surge current, 8.3ms single
half sine-wave superimposed on rated load
Rating for fusing (t
很抱歉,暂时无法提供与“ABS6 REG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+7.568351+0.91807
- 10+6.5396010+0.79328
- 100+4.52561100+0.54897
- 500+3.78104500+0.45865
- 国内价格 香港价格
- 1000+3.217951000+0.39035
- 2000+2.866002000+0.34766
- 5000+2.715155000+0.32936
- 10000+2.5140210000+0.30496
- 25000+2.4891325000+0.30194
