TSF30L60C C0G
TSF30L60C C0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-3
    DIODE ARRAY SCHOTT 60V ITO220AB
TSF30L60C C0G 数据手册
TSF30L45C – TSF30L60C Taiwan Semiconductor 30A, 45V - 60V Trench Schottky Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Patented Trench Schottky technology Excellent high temperature stability Low forward voltage Low power loss/ high efficiency High forward surge capability Compliant RoHS Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● PARAMETER VALUE UNIT IF 30 A VRRM 45 - 60 V IFSM 180 A TJ MAX 150 °C Package ITO-220AB Configuration Dual dies Switching mode power supply (SMPS) Adapters Lighting application On-board DC/DC converter MECHANICAL DATA ● ● ● ● ● ● ● Case: ITO-220AB Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Mounting torque: 0.56 N⋅m maximum Polarity: As marked Weight: 1.70g (approximately) ITO-220AB ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device TSF30L45C TSF30L60C TSF30L45C TSF30L60C UNIT Repetitive peak reverse voltage VRRM 45 60 V Reverse voltage, total rms value VR(RMS) 31 42 V IF 30 A IFSM 180 A dv/dt 10,000 V/µs Junction temperature TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C Forward current Surge peak forward current, 8.3ms single half sine-wave superimposed on rated load Critical rate of rise of off-state voltage 1 Version: F2105 TSF30L45C – TSF30L60C Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 4 °C/W Junction-to-case thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL TSF30L45C Forward voltage per diode (1) TSF30L60C IF = 15A, TJ = 25°C VF TSF30L45C TSF30L60C Reverse current @ rated VR per diode (2) IF = 15A, TJ = 125°C TJ = 25°C TJ = 125°C IR TYP MAX UNIT 0.48 0.55 V 0.55 0.62 V 0.46 0.53 V 0.51 0.58 V - 500 µA - 60 mA Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING TSF30LxC ITO-220AB 50 / Tube Notes: 1. “x” defines voltage from 45V(TSF30L45C) to 60V(TSF30L60C) 2 Version: F2105 TSF30L45C – TSF30L60C Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 30 25 CAPACITANCE (pF) 20 15 10 1000 100 5 0 f=1.0MHz Vsig=50mVp-p 10 50 75 100 125 150 0.1 1 CASE TEMPERATURE (°C) INSTANTANEOUS REVERSE CURRENT (mA) INSTANTANEOUS FORWARD CURRENT (A) 100 TJ=150°C 10 TJ=125°C 1 TJ=100°C 0.1 0.01 TJ=25°C 0.001 10 20 30 40 50 60 70 100 Fig.4 Typical Forward Characteristics 80 90 100 100 10 TSF30L45C 10 UF1DLW 1 TJ=150°C TJ=125°C TJ=125°C TJ=25°C 0.1 TJ=25°C 1 TJ=100°C 0.01 0.1 0.001 0.0 Pulse width 300μs 1% duty cycle Pulse width 0.3 0.2 0.4 0.5 0.4 0.6 0.7 0.6 0.8 0.9 1 0.8 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) FORWARD VOLTAGE (V) Fig.5 Typical Reverse Characteristics Fig.6 Typical Forward Characteristics 100 INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.3 Typical Reverse Characteristics TSF30L45C 10 REVERSE VOLTAGE (V) TJ=150°C TSF30L60C 10 1 TJ=100°C 0.1 TJ=125°C 0.01 TJ=25°C 0.001 0.0001 10 20 30 40 50 60 70 80 90 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 3 (A) 25 1.1 1.2 1.1 1.2 100 10 TSF30L60C UF1DLW 1 TJ=150°C 10 TJ=125°C TJ=125°C TJ=25°C 0.1 TJ=25°C 1 TJ=100°C 0.01 0.1 0.001 0.0 (A) AVERAGE FORWARD CURRENT (A) 35 Pulse width 300μs 1% duty cycle Pulse width 0.3 0.4 0.2 0.4 0.6 0.5 0.6 VOLTAGE 0.7 0.8 0.9 FORWARD (V) 1 0.8 Version: F2105 TSF30L45C – TSF30L60C Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS ITO-220AB MARKING DIAGRAM 4 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: F2105 TSF30L45C – TSF30L60C Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: F2105
TSF30L60C C0G 价格&库存
很抱歉,暂时无法提供与“TSF30L60C C0G”相匹配的价格&库存,您可以联系我们找货
