ESH3B R7G
ESH3B R7G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO214AB
    DIODE GEN PURP 100V 3A DO214AB
ESH3B R7G 数据手册
ESH3B – ESH3D Taiwan Semiconductor 3A, 100V - 200V Ultra Fast Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Glass passivated chip junction Ideal for automated placement Low profile package Ultra Fast recovery time for high efficiency Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 3 A VRRM 100 - 200 V IFSM 125 A TJ MAX 175 °C APPLICATIONS Package DO-214AB (SMC) Configuration Single die ● High frequency rectification ● Freewheeling application ● Switching mode converters and inverters in computer and telecommunication. MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AB (SMC) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.200g (approximately) DO-214AB (SMC) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device ESH3B ESH3C ESH3D ESH3B ESH3C ESH3D UNIT Repetitive peak reverse voltage VRRM 100 150 200 V Reverse voltage, total rms value VR(RMS) 70 105 140 V Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Junction temperature IF 3 A IFSM 125 A TJ - 55 to +175 °C Storage temperature TSTG - 55 to +175 °C 1 Version: I2102 ESH3B – ESH3D Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 12 °C/W Junction-to-ambient thermal resistance RӨJA 47 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR IF = 3A, TJ = 25°C (2) Junction capacitance Reverse recovery time TJ = 25°C SYMBOL TYP MAX UNIT VF - 0.9 V - 5 µA - 150 µA CJ 45 - pF trr - 20 ns IR TJ = 125°C 1MHz, VR = 4.0V IF = 0.5A, IR = 1.0A, Irr = 0.25A Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING ESH3x DO-214AB (SMC) 3,000 / Tape & Reel Notes: 1. “x” defines voltage from 100V(ESH3B) to 200V(ESH3D) 2 Version: I2102 ESH3B – ESH3D Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 60 50 3 CAPACITANCE (pF) 2 1 40 30 20 10 0 25 50 75 100 125 150 f=1.0MHz Vsig=50mVp-p 0 175 0.1 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C TJ=75°C 10 1 TJ=25°C 0.1 10 20 30 40 50 60 70 80 100 Fig.4 Typical Forward Characteristics 1000 90 100 10 10 UF1DLW 1 TJ=125°C 1 0.1 TJ=25°C 0.01 0.1 0.001 0.4 0.3 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% duty cyclePulse width 0.6 0.4 0.5 0.8 0.6 0.7 1.0 0.8 0.9 1.2 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 150 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.3 Typical Reverse Characteristics 100 10 REVERSE VOLTAGE (V) (A) AVERAGE FORWARD CURRENT (A) 4 8.3ms single half sine wave 125 100 75 50 25 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: I2102 1.2 ESH3B – ESH3D Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: I2102 ESH3B – ESH3D Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AB (SMC) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: I2102 ESH3B – ESH3D Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: I2102
ESH3B R7G 价格&库存
很抱歉,暂时无法提供与“ESH3B R7G”相匹配的价格&库存,您可以联系我们找货
