MBRF2035CT – MBRF20200CT
Taiwan Semiconductor
20A, 35V - 200V Schottky Barrier Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Low power loss, high efficiency
Guard ring for overvoltage protection
High surge current capability
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
A
VRRM
35 - 200
V
IFSM
150
A
TJ MAX
150
°C
Package
ITO-220AB
Configuration
Dual dies
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converters
MECHANICAL DATA
Case: ITO-220AB
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.70g (approximately)
ITO-220AB
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
MBRF MBRF MBRF MBRF MBRF MBRF MBRF MBRF MBRF
PARAMETER
SYMBOL 2035 2045 2050 2060 2080 2090 20100 20150 20200 UNIT
CT
CT
CT
CT
CT
CT
CT
CT
CT
CT
CT
CT
CT
CT
CT
CT
CT
CT
Marking code on
the device
Repetitive peak
reverse voltage
Reverse voltage,
total rms value
Forward current
Surge peak
forward current,
8.3ms single half
sine wave
superimposed on
rated load
Peak repetitive
reverse surge
(1)
current
VRRM
35
45
50
60
80
90
100
150
200
V
VR(RMS)
24
31
35
42
56
63
70
105
140
V
IF
A
IFSM
150
A
IRRM
1.0
0.5
1
A
Version: O2105
PARAMETER
CT
CT
CT
CT
CT
CT
CT
CT
CT
Peak repetitive
forward current
IFRM
(Rated VR, Square
wave, 20KHz)
Critical rate of rise
dv/dt
of off-state voltage
Junction
TJ
temperature
Storage
TSTG
temperature
Notes:
1. tp = 2.0μs, 1.0KHz
A
10,000
V/µs
-55 to +150
°C
-55 to +150
°C
THERMAL PERFORMANCE
PARAMETER
SYMBOL
MBRF2035CT-2060CT
Junction-to-case thermal
resistance
MBRF2080CT-20200CT
RӨJC
TYP
UNIT
1.5
°C/W
3.5
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
TYP
MAX
UNIT
0.80
V
0.85
V
0.95
V
0.84
V
0.95
V
1.00
0.95
V
1.05
V
MBRF2035CT
MBRF2045CT
MBRF2050CT
MBRF2060CT
MBRF2080CT IF = 10A,TJ = 25°C
MBRF2090CT
MBRF20100CT
MBRF20150CT
Forward voltage per diode
(1)
MBRF20200CT
VF
MBRF2035CT
MBRF2045CT
MBRF2050CT
MBRF2060CT
MBRF2080CT IF = 20A,TJ = 25°C
MBRF2090CT
MBRF20100CT
MBRF20150CT
MBRF20200CT
2
Version: O2105
PARAMETER
CONDITIONS
SYMBOL
MBRF2035CT
MBRF2045CT
MBRF2050CT
MBRF2060CT
MBRF2080CT IF = 10A,TJ = 125°C
MBRF2090CT
MBRF20100CT
MBRF20150CT
(1)
MBRF20200CT
TYP
MAX
UNIT
0.57
V
0.70
V
0.65
V
0.75
V
0.85
V
0.72
V
0.85
V
0.75
V
0.85
V
0.95
V
100
µA
15
mA
10
mA
30
mA
5
mA
2
mA
VF
MBRF2035CT
MBRF2045CT
MBRF2050CT
MBRF2060CT
MBRF2080CT IF = 20A,TJ = 125°C
MBRF2090CT
MBRF20100CT
MBRF20150CT
MBRF20200CT
MBRF2035CT
MBRF2045CT
MBRF2050CT
MBRF2060CT
MBRF2080CT TJ = 25°C
MBRF2090CT
MBRF20100CT
MBRF20150CT
Reverse current @ rated VR per
diode
(2)
MBRF20200CT
IR
MBRF2035CT
MBRF2045CT
MBRF2050CT
MBRF2060CT
MBRF2080CT TJ = 125°C
MBRF2090CT
MBRF20100CT
MBRF20150CT
MBRF20200CT
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
3
Version: O2105
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
MBRF20xCT
ITO-220AB
50 / Tube
MBRF20xCTH
ITO-220AB
50 / Tube
Notes:
1. “x” defines voltage from 35V(MBRF2035CT) to 200V(MBRF20200CT)
2. “H” means AEC-Q101 qualified
4
Version: O2105
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
CAPACITANCE (pF)
16
12
8
MBRF2035CT-2045CT
1000
MBRF2050CT-20200CT
100
4
f=1.0MHz
Vsig=50mVp-p
10
50
75
100
125
0.1
150
1
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
MBRF2035CT-2045CT
MBRF2050CT-20200CT
TJ=125°C
10
TJ=75°C
0.1
TJ=25°C
0.01
0.001
10
40
50
60
70
80
90
100
100 10
MBRF2035CT-2045CT
1
MBRF2050CT-2080CT
UF1DLW
10
TJ=125°C
TJ=25°C
0.1
MBRF2090CT-20100CT
1
0.01
MBRF20150CT-20200CT
0.1
0.001
0.2 0.3 0.4
0.4
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Pulse width 300μs
Pulse width
1% duty cycle
0.6
0.5
0.60.8 0.7 1.00.8
1.2
0.9
11.4
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
165
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
1000
1
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
100
10
(A)
AVERAGE FORWARD CURRENT (A)
24
150
135
8.3ms single half sine wave
120
105
90
75
60
45
30
15
10
100
NUMBER OF CYCLES AT 60 Hz
5
Version: O2105
1.2
Fig.6 Typical Transient Thermal Impedance
TRANSIENT THERMAL IMPEDANCE (°C/W)
100
10
1
0.01
0.1
1
10
100
PULSE DURATION (s)
6
Version: O2105
PACKAGE OUTLINE DIMENSIONS
ITO-220AB
MARKING DIAGRAM
7
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: O2105
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
8
Version: O2105
很抱歉,暂时无法提供与“MBRF20150CTHC0G”相匹配的价格&库存,您可以联系我们找货
