FR302G A0G
FR302G A0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-201AD
    DIODE GEN PURP 100V 3A DO201AD
FR302G A0G 数据手册
FR301G – FR307G Taiwan Semiconductor 3A, 50V - 1000V Fast Recovery Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available High current capability, Low VF High reliability High surge current capability Low power loss, high efficiency RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 3 A VRRM 50 - 1000 V IFSM 125 A TJ MAX 150 °C APPLICATIONS Package DO-201AD Configuration Single die ● DC to DC converter ● Switching mode converters and inverters ● General purpose MECHANICAL DATA ● ● ● ● ● ● Case: DO-201AD Molding compound meets UL 94V-0 flammability rating Terminal: Pure tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 1.20g (approximately) DO-201AD ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature Storage temperature FR 301G FR 301G FR 302G FR 302G FR 303G FR 303G FR 304G FR 304G FR 305G FR 305G FR 306G FR 306G VRRM 50 100 200 400 600 800 1000 V VR(RMS) 35 70 140 280 420 560 700 V SYMBOL FR UNIT 307G FR 307G IF 3 A IFSM 125 A TJ -55 to +150 °C TSTG -55 to +150 °C 1 Version: H2105 FR301G – FR307G Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER Junction-to-ambient thermal resistance SYMBOL TYP UNIT RӨJA 35 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR IF = 3A, TJ = 25°C TJ = 25°C (2) Junction capacitance Reverse recovery time SYMBOL TYP MAX UNIT VF - 1.3 V - 5 µA - 100 µA 30 - pF - 150 ns - 250 ns - 500 ns IR TJ = 125°C 1MHz, VR = 4.0V FR301G FR302G FR303G FR304G IF = 0.5A, IR = 1.0A, I = 0.25A FR305G rr FR306G FR307G CJ trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING FR3xG DO-201AD 1,250 / Tape & Reel FR3xG A0G DO-201AD 500 / Ammo box FR3xGH DO-201AD 1,250 / Tape & Reel FR3xGHA0G DO-201AD 500 / Ammo box Notes: 1. "x" defines voltage from 50V (FR301G) to 1000V (FR307G) 2. “H” means AEC-Q101 qualified 2 Version: H2105 FR301G – FR307G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 3 CAPACITANCE (pF) 2 1 10 f=1.0MHz Vsig=50mVp-p 1 0 25 50 75 100 125 1 150 10 ANBIENT TEMPERATURE (°C) REVERSE VOLTAGE (V) Fig.4 Typical Forward Characteristics INSTANTANEOUS FORWARD CURRENT (A) 100 TJ=125°C 10 TJ=75°C 1 TJ=25°C 0.1 20 30 40 50 60 70 80 90 100 1010 UF1DLW 1 TJ=125°C TJ=25°C 10.1 0.01 0.1 0.001 0.60.3 0.7 0.40.8 0.5 0.9 Pulse Pulse width width 300μs 300μs 1% duty cycle Pulse width 1 0.6 1.1 0.7 1.20.8 1.3 0.91.4 11.5 1.1 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig.5 Maximum Non-Repetitive Forward Surge Current 150 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (µA) Fig.3 Typical Reverse Characteristics 10 100 (A) AVERAGE FORWARD CURRENT (A) 4 8.3ms single half sine wave 125 100 75 50 25 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: H2105 1.2 FR301G – FR307G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: H2105 FR301G – FR307G Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-201AD MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: H2105 FR301G – FR307G Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: H2105
FR302G A0G 价格&库存
很抱歉,暂时无法提供与“FR302G A0G”相匹配的价格&库存,您可以联系我们找货
