UG54G A0G
UG54G A0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-201AD
    DIODE GEN PURP 200V 5A DO201AD
UG54G A0G 数据手册
UG54G – UG58G Taiwan Semiconductor 5A, 200V - 600V Ultra Fast Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available High current capability High reliability High surge current capability Low power loss RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 5 A VRRM 200 - 600 V IFSM 65 A TJ MAX 150, 175 °C Package DO-201AD Configuration Single die ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● Case: DO-201AD Molding compound meets UL 94V-0 flammability rating Terminal: Pure tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 1.10g (approximately) DO-201AD ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device UG54G UG56G UG58G UG54G UG56G UG58G UNIT Repetitive peak reverse voltage VRRM 200 400 600 V Reverse voltage, total rms value VR(RMS) 140 280 420 V Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature IF 5 A IFSM 65 A TJ -55 to +175 -55 to +150 °C Storage temperature TSTG -55 to +175 -55 to +150 °C 1 Version: F2111 UG54G – UG58G Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL Junction-to-lead thermal resistance UG54G UG56G UG58G TYP UNIT 11 °C/W 15 °C/W RӨJL ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS Reverse current @ rated VR TYP MAX UNIT UG54G - 1.05 V UG56G IF = 5A, TJ = 25°C - 1.55 V - 2.10 V - - V UG56G IF = 5A, TJ = 125°C - - V UG58G UG54G UG56G TJ = 25°C UG58G UG54G UG56G TJ = 125°C UG58G IF = 0.5A, IR = 1.0A, Irr = 0.25A - 1.70 V - 10 µA - 30 µA - 100 µA - 200 µA - 20 ns UG58G (1) VF UG54G (2) Reverse recovery time SYMBOL IR trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING UG5xG DO-201AD 1,250 / Tape & Reel UG5xG A0G DO-201AD 500 / Ammo box UG5xGH DO-201AD 1,250 / Tape & Reel UG5xGHA0G DO-201AD 500 / Ammo box Notes: 1. "x" defines voltage from 200V (UG54G) to 600V (UG58G) 2. “H” means AEC-Q101 qualified 2 Version: F2111 UG54G – UG58G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 5 4 CAPACITANCE (pF) UG54G-56G 3 UG58G 2 10 1 f=1.0MHz Vsig=50mVp-p 0 1 25 50 75 100 125 150 175 0.1 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 1 0.1 0.01 TJ=25°C 0.001 20 30 40 50 60 70 80 90 100 10 10 TJ=125°C 1 UF1DLW TJ=125°C TJ=25°C 10.1 UG54G UG56G UG58G 0.01 0.1 0.001 0.20.3 0.4 0.6 0.4 0.80.51 TJ=25°C Pulse width 300μs 1% 1% duty duty cycle cycle Pulse width 1.2 1.40.71.6 0.8 1.8 0.6 20.92.2 2.4 1 1.1 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig.5 Maximum Non-Repetitive Forward Surge Current PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (µA) Fig.4 Typical Forward Characteristics 100 10 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 (A) AVERAGE FORWARD CURRENT (A) 6 70 65 60 55 50 45 40 35 30 25 20 15 10 5 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: F2111 1.2 UG54G – UG58G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: F2111 UG54G – UG58G Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-201AD MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: F2111 UG54G – UG58G Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: F2111
UG54G A0G
物料型号为UG54G、UG56G、UG58G,是台湾半导体公司生产的5A、200V-600V超快速整流器。
器件简介包括AEC-Q101认证、高电流能力、高可靠性、高浪涌电流能力、低功耗、符合RoHS标准、无卤素等特性。
引脚分配为阴极和阳极。
参数特性包括正向电流5A、反向电压200-600V、浪涌峰值正向电流65A、最大结温150°C或175°C。
功能详解涉及热性能、电气规格、反向恢复时间等。
应用信息包括DC-DC转换器、开关模式转换器和逆变器、续流应用。
封装信息为DO-201AD,符合UL 94V-0可燃性等级,终端为纯锡镀层引线,符合J-STD-002可焊性,通过JESD 201类2须测试。
UG54G A0G 价格&库存
很抱歉,暂时无法提供与“UG54G A0G”相匹配的价格&库存,您可以联系我们找货
