SRA10100 C0G
SRA10100 C0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-2
    DIODE SCHOTTKY 100V 10A TO220AC
SRA10100 C0G 数据手册
SRA1020 – SRA10150 Taiwan Semiconductor 10A, 20V - 150V Schottky Barrier Rectifier FEATURES ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Low power loss, high efficiency Guard ring for overvoltage protection High surge current capability RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converters PARAMETER VALUE UNIT IF 10 A VRRM 20 - 150 V IFSM 170 A TJ MAX 125, 150 °C Package TO-220AC Configuration Single die MECHANICAL DATA ● ● ● ● ● ● ● Case: TO-220AC Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.88g (approximately) TO-220AC ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) Repetitive peak reverse voltage VRRM SRA 1020 SRA 1020 20 Reverse voltage, total rms value VR(RMS) 14 PARAMETER SYMBOL Marking code on the device Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Critical rate of rise of off-state voltage Junction temperature Storage temperature SRA 1030 SRA 1030 30 SRA 1040 SRA 1040 40 SRA 1050 SRA 1050 50 SRA 1060 SRA 1060 60 21 28 35 42 SRA SRA SRA UNIT 1090 10100 10150 SRA SRA SRA 1090 10100 10150 90 100 150 V 63 70 105 V IF 10 A IFSM 170 A dv/dt 10,000 V/µs TJ -55 to +125 TSTG -55 to +150 -55 to +150 1 °C °C Version: K2103 SRA1020 – SRA10150 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER Junction-to-case resistance SYMBOL TYP UNIT RӨJC 2 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR (2) SRA1020 SRA1030 SRA1040 SRA1050 SRA1060 SRA1090 SRA10100 SRA10150 SRA1020 SRA1030 SRA1040 SRA1050 SRA1060 SRA1090 SRA10100 SRA10150 SRA1020 SRA1030 SRA1040 SRA1050 SRA1060 SRA1090 SRA10100 SRA10150 SRA1020 SRA1030 SRA1040 SRA1050 SRA1060 SRA1090 SRA10100 SRA10150 IF = 10A, TJ = 25°C SYMBOL VF TYP MAX UNIT - 0.55 V - 0.70 V - 0.85 V - 0.95 V - 500 µA - 100 µA - 15 mA - 10 mA - - mA - - mA - 5 mA TJ = 25°C TJ = 100°C IR TJ = 125°C Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SRA10x TO-220AC 50 / Tube SRA10xH TO-220AC 50 / Tube Notes: 1. “x” defines voltage from 20V(SRA1020) to 150V(SRA10150) 2. “H” means AEC-Q101 qualified 2 Version: K2103 SRA1020 – SRA10150 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 SRA1050-SRA10150 10 CAPACITANCE (pF) 8 6 SRA1020-SRA1040 4 1000 2 f=1.0MHz Vsig=50mVp-p 100 0 25 50 75 100 125 0.1 150 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=75°C 0.01 TJ=25°C 0.001 20 30 40 50 60 70 80 90 100 100 10 SRA1090-SRA10100 UF1DLW SRA1050-SRA1060 1 10 SRA1020-SRA1040 TJ=125°C TJ=25°C 0.1 1 0.01 SRA10150 0.001 0.1 0.5 0.20.3 0.30.4 0.4 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs Pulse width 1% duty cycle 0.6 0.5 0.7 0.6 0.8 0.7 0.9 0.8 10.9 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 180 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) TJ=100°C 10 100 Fig.4 Typical Forward Characteristics 10 0.1 10 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 1 1 (A) AVERAGE FORWARD CURRENT (A) 12 160 140 120 100 80 60 40 20 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: K2103 1.2 SRA1020 – SRA10150 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Impedance TRANSIENT THERMAL IMPEDANCE (°C/W) 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 4 Version: K2103 SRA1020 – SRA10150 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-220AC MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: K2103 SRA1020 – SRA10150 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: K2103
SRA10100 C0G 价格&库存
很抱歉,暂时无法提供与“SRA10100 C0G”相匹配的价格&库存,您可以联系我们找货
