TPMR6G – TPMR6J
Taiwan Semiconductor
6A, 400V - 600V Super Fast Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Very low profile, typical height of 1.1mm
175°C operating junction temperature
Glass passivated chip junction
Low conduction loss
Low leakage current
High forward surge capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
6
A
VRRM
400 - 600
V
IFSM
100
A
TJ MAX
175
°C
Package
TO-277A (SMPC)
Configuration
Single die
APPLICATIONS
● DC to DC converter
● Switching mode converters and inverters
● Freewheeling application
MECHANICAL DATA
Case: TO-277A (SMPC)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.095g (approximately)
TO-277A (SMPC)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
TPMR6G
TPMR6J
MR6G
MR6J
UNIT
Repetitive peak reverse voltage
VRRM
400
600
V
Reverse voltage, total rms value
VR(RMS)
280
420
V
Forward current
Surge peak forward current, 8.3ms single half
sine wave superimposed on rated load
Junction temperature
IF
6
A
IFSM
100
A
TJ
-55 to +175
°C
Storage temperature
TSTG
-55 to +175
°C
1
Version: C2103
TPMR6G – TPMR6J
THERMAL PERFORMANCE
PARAMETER
Junction-to-lead thermal resistance
SYMBOL
TYP
UNIT
RӨJL
9.5
°C/W
RӨJA
86
°C/W
(1)
Junction-to-ambient thermal resistance
(2)
Notes:
1. Mounted on FR4 PCB with 16mm x 16mm Cu pad area
2. Free air, mounted on recommended pad
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
TPMR6G
Forward voltage
TPMR6J
(1)
TPMR6G
TPMR6J
Reverse current @ rated VR
IF = 6A, TJ = 25°C
VF
IF = 6A, TJ = 125°C
TJ = 25°C
(2)
IR
TJ = 125°C
Junction capacitance
SYMBOL
1MHz, VR = 4.0V
CJ
Reverse recovery time
TPMR6G IF = 0.5A, IR = 1.0A
TPMR6J Irr = 0.25A
trr
TPMR6G IF = 1A, di/dt = -50A/μs
TPMR6J VR = 30V
trr
TYP
MAX
UNIT
1.20
V
1.80
V
1.00
V
V
10
µA
500
µA
60
pF
35
ns
40
ns
60
ns
ns
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
TPMR6x
TO-277A (SMPC)
6,000 / Tape & Reel
Notes:
1. “x” defines voltage from 400V(TPMR6G) to 600V(TPMR6J)
2
Version: C2103
TPMR6G – TPMR6J
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
6
5
CAPACITANCE (pF)
4
3
2
100
1
50
75
100
125
150
f=1.0MHz
Vsig=50mVp-p
10
175
0.1
1
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
1
TJ=25°C
10
40
50
60
70
80
100
Fig.4 Typical Forward Characteristics
10
90
100
10 10
TPMR6G
TPMR6J
1
UF1DLW
TJ=125°C
TJ=125°C
1
0.1
TJ=25°C
TJ=25°C
0.01
Pulse width 300μs
1% duty cycle
Pulse width
0.1
0.001
0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 1.3 1.4
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
110
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.3 Typical Reverse Characteristics
0.1
10
REVERSE VOLTAGE (V)
(A)
AVERAGE FORWARD CURRENT (A)
7
100
8.3ms single half sine wave
90
80
70
60
50
40
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: C2103
1.2
TPMR6G – TPMR6J
PACKAGE OUTLINE DIMENSIONS
TO-277A (SMPC)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
P/N
YW
F
4
= Marking Code
= Date Code
= Factory Code
Version: C2103
TPMR6G – TPMR6J
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: C2103
很抱歉,暂时无法提供与“TPMR6G S1G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.22607
- 200+1.28726
- 500+1.24427
- 1500+1.22300
