GBU601 – GBU607
Taiwan Semiconductor
6A, 50V - 1000V Standard Bridge Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Ideal for printed circuit board
High case dielectric strength of 1500VRMS
High surge current capability
Typical IR less than 0.1μA
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
6
A
VRRM
50 - 1000
V
IFSM
175
A
TJ MAX
150
°C
Package
GBU
Configuration
Quad
APPLICATIONS
● Switching mode power supply (SMPS)
● Adapters
● Lighting application
MECHANICAL DATA
Case: GBU
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Polarity: As marked
Weight: 4.00g (approximately)
GBU
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Repetitive peak reverse voltage
VRRM
GBU
601
GBU
601
50
Reverse voltage, total rms value
VR(RMS)
35
PARAMETER
SYMBOL
Marking code on the device
Forward current
Surge peak forward current, 8.3ms
single half sine-wave superimposed
on rated load
Rating for fusing (t
很抱歉,暂时无法提供与“GBU601 D2G”相匹配的价格&库存,您可以联系我们找货
