SRAF520 – SRAF5150
Taiwan Semiconductor
5A, 20V - 150V Schottky Barrier Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Low power loss, high efficiency
Guard ring for over-voltage protection
High surge current capability
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
5
A
VRRM
20 - 150
V
IFSM
120
A
TJ MAX
125, 150
°C
Package
ITO-220AC
Configuration
Single die
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converter
MECHANICAL DATA
Case: ITO-220AC
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.70g (approximately)
ITO-220AC
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on
the device
Repetitive peak
reverse voltage
Reverse voltage
total rms value
Forward current
Surge peak forward
current, 8.3ms
single half sine wave
superimposed on
rated load
Critical rate of rise
of off-state voltage
Junction
temperature
Storage
temperature
SRAF
520
SRAF
520
SRAF
530
SRAF
530
SRAF
540
SRAF
540
SRAF
550
SRAF
550
SRAF
560
SRAF
560
SRAF
590
SRAF
590
SRAF
5100
SRAF
5100
VRRM
40
50
60
90
100
150
V
VR(RMS)
14
21
28
35
42
63
70
105
V
SYMBOL
SRAF
UNIT
5150
SRAF
5150
IF
5
A
IFSM
120
A
dv/dt
10,000
V/µs
TJ
-55 to +125
-55 to +150
TSTG
-55 to +150
1
°C
°C
Version: K2105
SRAF520 – SRAF5150
THERMAL PERFORMANCE
PARAMETER
Junction-to-case resistance
SYMBOL
TYP
UNIT
RӨJC
10
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
(2)
SRAF520
SRAF530
SRAF540
SRAF550
SRAF560
SRAF590
SRAF5100
SRAF5150
SRAF520
SRAF530
SRAF540
SRAF550
SRAF560
SRAF590
SRAF5100
SRAF5150
SRAF520
SRAF530
SRAF540
SRAF550
SRAF560
SRAF590
SRAF5100
SRAF5150
SRAF520
SRAF530
SRAF540
SRAF550
SRAF560
SRAF590
SRAF5100
SRAF5150
IF = 5A, TJ = 25°C
SYMBOL
VF
TYP
MAX
UNIT
0.55
V
0.70
V
0.85
V
0.95
V
500
µA
200
µA
15
mA
10
mA
mA
mA
5
mA
TJ = 25°C
TJ = 100°C
IR
TJ = 125°C
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
SRAF5x
ITO-220AC
50 / Tube
SRAF5xH
ITO-220AC
50 / Tube
Notes:
1. “x” defines voltage from 20V(SRAF520) to 150V(SRAF5150)
2. “H” means AEC-Q101 qualified
2
Version: K2105
SRAF520 – SRAF5150
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
600
SRAF550-5150
500
5
CAPACITANCE (pF)
AVERAGE FORWARD CURRENT (A)
6
4
3
SRAF520-540
2
400
SRAF520-560
300
200
SRAF590-5150
100
1
f=1.0MHz
Vsig=50mVp-p
50
75
100
125
0.1
150
1
CASE TEMPERATURE (°C)
TJ=75°C
0.1
TJ=25°C
0.01
0.001
10
40
50
60
70
80
90
100
10 10
SRAF520-540
1
UF1DLW
SRAF550-560
TJ=125°C
TJ=25°C
10.1
(A)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
1
SRAF590-5100
0.01
0.1
0.001
0.1
0.3
SRAF5150
Pulse width 300μs
Pulse width
1% duty cycle
0.3
0.4
0.5
0.5
0.6
0.7
0.7
0.8
0.9
0.9
1
1.1
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Fig.5 Maximum Non-Repetitive Forward Surge Current
140
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
100
10
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
SRAF520-560
SRAF590-5150
10
120
100
80
60
40
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: K2105
1.2
SRAF520 – SRAF5150
Fig.6 Typical Transient Thermal Characteristics
TRANSIENT THERMAL IMPEDANCE (°C/W)
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
4
Version: K2105
SRAF520 – SRAF5150
PACKAGE OUTLINE DIMENSIONS
ITO-220AC
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: K2105
SRAF520 – SRAF5150
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: K2105
很抱歉,暂时无法提供与“SRAF550 C0G”相匹配的价格&库存,您可以联系我们找货
