UF1A – UF1M
Taiwan Semiconductor
1A, 50V - 1000V High Efficient Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Glass passivated chip junction
Excellent high temperature switching
Soft recovery characteristics
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
● DC to DC converter
● Switching mode converters and inverters
● Freewheeling application
PARAMETER
VALUE
UNIT
IF
1
A
VRRM
50 - 1000
V
IFSM
30
A
TJ MAX
150
°C
Package
DO-204AL (DO-41)
Configuration
Single die
MECHANICAL DATA
Case: DO-204AL (DO-41)
Molding compound meets UL 94V-0 flammability rating
Terminal: Pure tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.330g (approximately)
DO-204AL (DO-41)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL UF1A UF1B UF1D UF1G UF1J UF1K UF1M UNIT
Marking code on the device
UF1A
UF1B
UF1D
UF1G
UF1J
UF1K
UF1M
Repetitive peak reverse voltage
VRRM
50
100
200
400
600
800
1000
V
Reverse voltage, total rms value
VR(RMS)
35
70
140
280
420
560
700
V
Forward current
Surge peak forward current,
8.3ms single half sine wave
superimposed on rated load
Junction temperature
IF
1
A
IFSM
30
A
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
1
Version: G2104
UF1A – UF1M
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
15
°C/W
Junction-to-ambient thermal resistance
RӨJA
60
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
(1)
Reverse current @ rated VR
(2)
CONDITIONS
UF1A
UF1B
UF1D
UF1G IF = 1A, TJ = 25°C
UF1J
UF1K
UF1M
TJ = 25°C
TJ = 125°C
Junction capacitance
Reverse recovery time
1MHz, VR = 4.0V
UF1A
UF1B
UF1D
I = 0.5A, IR = 1.0A,
UF1G F
I = 0.25A
UF1J rr
UF1K
UF1M
SYMBOL
TYP
MAX
UNIT
1.0
V
1.7
V
5
µA
150
µA
17
pF
50
ns
75
ns
VF
IR
CJ
trr
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
UF1x
DO-204AL (DO-41)
5,000 / Tape & Reel
UF1x A0G
DO-204AL (DO-41)
3,000 / Ammo box
UF1xH
DO-204AL (DO-41)
5,000 / Tape & Reel
UF1xHA0G
DO-204AL (DO-41)
3,000 / Ammo box
Notes:
1. “x” defines voltage from 50V (UF1A) to 1000V (UF1M)
2. “H” means AEC-Q101 qualified
2
Version: G2104
UF1A – UF1M
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
CAPACITANCE (pF)
1
50
75
100
125
UF1J-UF1M
10
UF1A-UF1G
f=1.0MHz
Vsig=50mVp-p
1
150
0.1
1
AMBIENT TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
100
TJ=125°C
10
1
0.1
TJ=25°C
TJ=100°C
0.01
10
40
50
60
70
80
100
Fig.4 Typical Forward Characteristics
1000
90
100
10 10
1
UF1A-UF1G
UF1DLW
TJ=125°C
TJ=25°C
1
0.1
UF1J-UF1M
0.01
0.1
0.001
0.5
0.7
0.9
1.1
0.3
0.4
0.5
0.6
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Pulse width 300μs
1% duty cycle
Pulse width
1.3
0.7
1.5
0.8
1.7
0.9
1.9
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
35
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (µA)
Fig.3 Typical Reverse Characteristics
UF1A-UF1G
UF1J-UF1M
10
REVERSE VOLTAGE (V)
(A)
AVERAGE FORWARD CURRENT (A)
2
30
25
10
5
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: G2104
1.2
UF1A – UF1M
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: G2104
UF1A – UF1M
PACKAGE OUTLINE DIMENSIONS
DO-204AL (DO-41)
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: G2104
UF1A – UF1M
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: G2104
很抱歉,暂时无法提供与“UF1B R1G”相匹配的价格&库存,您可以联系我们找货
