SBS34 REG
SBS34 REG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SMD4
    BRIDGE RECT 1PHASE 40V 3A ABS
SBS34 REG 数据手册
SBS34 – SBS36 Taiwan Semiconductor 3A, 40V - 60V Schottky Bridge Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Schottky technology Ideal for automated placement High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 3 A VRRM 40 - 60 V IFSM 80 A TJ MAX 125, 150 °C APPLICATIONS Package ABS Configuration Quad ● Charging circuit ● Power over Ethernet ● Lighting application MECHANICAL DATA ● ● ● ● ● ● Case: ABS Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 0.090g (approximately) ABS ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device SBS34 SBS36 SBS34 SBS36 UNIT Repetitive peak reverse voltage VRRM 40 60 V Reverse voltage, total rms value VR(RMS) 28 42 V Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Rating for fusing (t
SBS34 REG 价格&库存
很抱歉,暂时无法提供与“SBS34 REG”相匹配的价格&库存,您可以联系我们找货
