SS22L – SS215L
Taiwan Semiconductor
2A, 20V - 150V Schottky Barrier Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Low power loss, high efficiency
Ideal for automated placement
Guard ring for overvoltage protection
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
2
A
VRRM
20 - 150
V
IFSM
50
A
TJ MAX
125, 150
°C
APPLICATIONS
Package
Sub SMA
Configuration
Single die
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converters
MECHANICAL DATA
Case: Sub SMA
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.019g (approximately)
Sub SMA
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
SS
22L
SS
23L
SS
24L
SS
25L
SS
26L
SS
SS
SS
UNIT
29L 210L 215L
22L
23L
24L
25L
26L
29L
20L
2AL
Repetitive peak reverse voltage
VRRM
40
50
60
90
100
150
V
Reverse voltage, total rms value
VR(RMS)
14
21
28
35
42
63
70
105
V
Forward current
Peak forward surge current,
8.3ms single half sine-wave
superimposed on rated load
Critical rate of rise of off-state
voltage
Junction temperature
Storage temperature
IF
2
A
IFSM
50
A
dv/dt
10,000
V/μs
TJ
- 55 to +125
TSTG
- 55 to +150
- 55 to +150
1
°C
°C
Version: O2103
SS22L – SS215L
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
17
°C/W
Junction-to-ambient thermal resistance
RӨJA
75
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
(2)
SS22L
SS23L
SS24L
SS25L
SS26L
SS29L
SS210L
SS215L
SS22L
SS23L
SS24L
SS25L
SS26L
SS29L
SS210L
SS215L
SS22L
SS23L
SS24L
SS25L
SS26L
SS29L
SS210L
SS215L
SS22L
SS23L
SS24L
SS25L
SS26L
SS29L
SS210L
SS215L
IF = 2A, TJ = 25°C
SYMBOL
VF
TYP
MAX
UNIT
0.50
V
0.70
V
0.85
V
0.95
V
400
µA
100
µA
15
mA
10
mA
mA
mA
mA
5
mA
TJ = 25°C
TJ = 100°C
IR
TJ = 125°C
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
SS2xL
Sub SMA
10,000 / Tape & Reel
Notes:
1. “x” defines voltage from 20V(SS22L) to 150V(SS215L)
2
Version: O2103
SS22L – SS215L
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
SS25L - SS215L
CAPACITANCE (pF)
2
1
SS22L - SS24L
100
10
f=1.0MHz
Vsig=50mVp-p
1
50
75
100
125
0.1
150
1
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
1
TJ=75°C
0.1
TJ=25°C
0.01
0.001
10
40
50
60
70
80
90
100
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
10 10
1
SS22L - SS24L
UF1DLW
SS25L - SS26L
TJ=125°C
1
0.1
TJ=25°C
SS29L - SS210L
SS215L
0.01
0.1
0.001
0.2
0.4
0.3
0.4
Pulse width 300μs
1% duty cycle
Pulse width
0.6
0.5
0.8
1.0
0.6
0.7
0.8
FORWARD VOLTAGE (V)
1.2
0.9
1.4
1
1.1
Fig.5 Maximum Non-Repetitive Forward Surge Current
60
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
100
10
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
SS22L - SS24L
SS25L - SS215L
10
(A)
AVERAGE FORWARD CURRENT (A)
3
8.3ms single half sine wave
50
40
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: O2103
1.2
SS22L – SS215L
Fig.6 Typical Transient Thermal Impedance
TRANSIENT THERMAL IMPEDANCE (°C/W)
100
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
4
Version: O2103
SS22L – SS215L
PACKAGE OUTLINE DIMENSIONS
Sub SMA
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: O2103
SS22L – SS215L
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: O2103
很抱歉,暂时无法提供与“SS24LHMHG”相匹配的价格&库存,您可以联系我们找货
