BAS85
Taiwan Semiconductor
200mW , Hermetically Sealed Glass Fast Switching
Schottky Barrier Diodes
FEATURES
KEY PARAMETERS
● Low forward voltage
● Ideal for automated placement
● Compliant to RoHS directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
PD
200
mW
VRRM
30
V
IFSM
4
A
VF at IF=100mA
0.8
V
TJ Max.
125
°C
APPLICATIONS
Adapters
For switching power supply
Low stored charge
Inverter
Package
MINI MELF
Configuration
Single die
MECHANICAL DATA
Case: Mini-MELF
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 1A whisker test
Polarity: Indicated by cathode band
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Power dissipation
SYMBOL
BAS85
UNIT
PD
200
mW
VRRM
VR
IF(AV)
IFSM
30
30
200
4
V
V
mA
A
Junction temperature range
TJ
-65 to +125
°C
Storage temperature range
TSTG
-65 to +125
°C
Repetitive peak reverse voltage
Maximum DC blocking voltage
Average forward rectified current
Peak forward surge current
1
Version:D1804
BAS85
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Reverse voltage
Reverse current
Forward voltage
CONDITIONS
(2)
(2)
(1)
SYMBOL
MIN
TYP
MAX
UNIT
IR = 10 μA, TJ = 25°C
VR
30
V
VR = 25 V, TJ = 25°C
IR
2
μA
IF = 0.1mA, TJ = 25°C
0.24
IF = 1mA, TJ = 25°C
0.32
0.40
IF = 30mA, TJ = 25°C
0.50
IF = 100mA, TJ = 25°C
0.80
IF = 10mA, TJ = 25°C
VF
V
Junction capacitance
1 MHz, VR=1V
CJ
10
pF
Reverse recovery time
IF = IR = 10mA
RL = 100Ω , IRR = 1mA
trr
5
ns
Notes:
1. Pulse test with PW=0.3 ms
2. Pulse test with PW=30 ms
ORDERING INFORMATION
PART NO.
PACKAGE
PACKING
BAS85 L0
MINI MELF
10K / 13" Reel
BAS85 L0G
MINI MELF
10K / 13" Reel
BAS85 L1
MINI MELF
2.5K / 7" Reel
BAS85 L1G
MINI MELF
2.5K / 7" Reel
2
Version:D1804
BAS85
PACKAGE OUTLINE DIMENSION
Mini-MELF
Unit (mm)
DIM.
C
Unit (inch)
Min
Max
Min
Max
A
3.30
3.70
0.130
0.146
B
1.40
1.60
0.055
0.063
C
0.20
0.50
0.008
0.020
B
A
SUGGEST PAD LAYOUT
Unit (mm)
Unit (inch)
Typ.
Typ.
A
1.25
0.049
DIM.
3
B
2.00
0.079
C
2.50
0.098
D
5.00
0.197
Version:D1804
BAS85
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
4
Version:D1804
很抱歉,暂时无法提供与“BAS85 L1G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 30000+0.2248830000+0.02910
- 62500+0.2065262500+0.02672
- 125000+0.19188125000+0.02483
- 250000+0.18395250000+0.02380
