MUR160AHR1G
MUR160AHR1G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-204AL
    DIODE GEN PURP 600V 1A DO204AL
MUR160AHR1G 数据手册
MUR160A – MUR190A Taiwan Semiconductor 1A, 600V - 900V High Efficient Rectifier FEATURES ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available High efficiency, low VF High reliability 175°C operating junction temperature RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application PARAMETER VALUE UNIT IF 1 A VRRM 600 - 900 V IFSM 35 A TJ MAX 150 - 175 °C Package DO-204AL (DO-41) Configuration Single die MECHANICAL DATA ● ● ● ● ● ● Case: DO-204AL (DO-41) Molding compound meets UL 94V-0 flammability rating Terminal: Pure tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.330g (approximately) DO-204AL (DO-41) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device MUR160A MUR190A MUR160A MUR190A UNIT Repetitive peak reverse voltage VRRM 600 900 V Reverse voltage, total rms value VR(RMS) 420 630 V Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature IF 1 A IFSM 35 A TJ -55 to +175 -55 to +150 °C Storage temperature TSTG -55 to +175 -55 to +150 °C 1 Version: H2107 MUR160A – MUR190A Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJA 50 °C/W Junction-to-ambient thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS MUR160A Forward voltage MUR190A (1) MUR160A MUR190A Reverse current @ rated VR Junction capacitance Reverse recovery time IF = 1A, TJ = 25°C VF IF = 1A, TJ = 125°C TJ = 25°C (2) IR TJ = 125°C MUR160A MUR190A MUR160A MUR190A SYMBOL 1MHz, VR = 4.0V CJ IF = 0.5A, IR = 1.0A, Irr = 0.25A trr TYP MAX UNIT - 1.25 V - 1.70 V - 1.05 V - 1.50 V - 5 µA - 150 µA 27 - pF 15 - pF - 50 ns - 75 ns Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING MUR1xA DO-204AL (DO-41) 5,000 / Tape & Reel MUR1xA A0G DO-204AL (DO-41) 3,000 / Ammo box MUR1xAH DO-204AL (DO-41) 5,000 / Tape & Reel MUR1xAHA0G DO-204AL (DO-41) 3,000 / Ammo box Notes: 1. “x” defines voltage from 600V (MUR160A) to 900V (MUR190A) 2. “H” means AEC-Q101 qualified 2 Version: H2107 MUR160A – MUR190A Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 CAPACITANCE (pF) 1 MUR160A MUR160A 10 MUR190A MUR190A 0 25 50 75 100 125 150 f=1.0MHz Vsig=50mVp-p 1 175 1 10 LEAD TEMPERATURE (°C) REVERSE VOLTAGE (V) Fig.4 Typical Forward Characteristics INSTANTANEOUS FORWARD CURRENT (A) 10 1 TJ=100°C 0.1 0.01 TJ=25°C 0.001 20 30 40 50 60 70 80 90 100 1010 MUR160A MUR190A 1 UF1DLW TJ=100°C TJ=125°C TJ=25°C 10.1 TJ=25°C 0.01 Pulse width 300μs 1% duty cycle Pulse width 0.1 0.001 0.5 0.7 0.9 1.1 1.3 1.5 1.7 0.3 0.4 0.5 0.6 0.7 0.8 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 1.9 0.9 2.1 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 40 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (µA) Fig.3 Typical Reverse Characteristics 10 100 (A) AVERAGE FORWARD CURRENT (A) 2 35 8.3ms single half sine wave 30 25 20 15 10 5 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: H2107 1.2 MUR160A – MUR190A Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: H2107 MUR160A – MUR190A Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-204AL (DO-41) MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: H2107 MUR160A – MUR190A Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: H2107
MUR160AHR1G 价格&库存
很抱歉,暂时无法提供与“MUR160AHR1G”相匹配的价格&库存,您可以联系我们找货
