TS10KL60HD3G
TS10KL60HD3G
    TAIWANSEMICONDUCTOR(台湾半导体)
    SIP4
    BRIDGE RECT 1PHASE 600V 10A KBJL
TS10KL60HD3G 数据手册
TS10KL60 – TS10KL100 Taiwan Semiconductor 10A, 600V - 1000V Standard Bridge Rectifier FEATURES KEY PARAMETERS ● AEC-Q101 qualified available ● Thin Single-in-line low profile package ideal for compact required circuit ● Glass passivated chip junction ● High surge current capability ● UL Recognized File # E-326243 ● RoHS Compliant ● Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 10 A VRRM 600 - 1000 V IFSM 180 A TJ MAX 150 °C Package KBJL Configuration Quad APPLICATIONS ● Switching mode power supply ● Adapters ● Lighting application MECHANICAL DATA ● ● ● ● ● ● ● Case: KBJL Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Mounting torque: 0.56 N⋅m maximum Polarity: As marked Weight: 2.50g (approximately) KBJL ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL TS10KL60 TS10KL80 TS10KL100 UNIT Marking code on the device TS10KL60 TS10KL80 TS10KL100 Repetitive peak reverse voltage VRRM 600 800 1000 V Reverse voltage, total rms value VR(RMS) 420 560 700 V Forward current Surge peak forward current, 8.3ms single half sine-wave superimposed on rated load Rating for fusing (t
TS10KL60HD3G 价格&库存
很抱歉,暂时无法提供与“TS10KL60HD3G”相匹配的价格&库存,您可以联系我们找货
