SF46GHB0G
SF46GHB0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-201AD
    DIODE GEN PURP 400V 4A DO201AD
SF46GHB0G 数据手册
SF41G – SF48G Taiwan Semiconductor 4A, 50V - 600V Super Fast Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available High current capability, Low VF High reliability High surge current capability Low power loss RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 4 A VRRM 50 - 600 V IFSM 125 A TJ MAX 150 °C APPLICATIONS Package DO-201AD Configuration Single die ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● Case: DO-201AD Molding compound meets UL 94V-0 flammability rating Terminal: Pure tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 1.10g (approximately) DO-201AD ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature Storage temperature SF 41G SF 41G SF 42G SF 42G SF 43G SF 43G SF 44G SF 44G SF 45G SF 45G SF 46G SF 46G SF 47G SF 47G SF UNIT 48G SF 48G VRRM 50 100 150 200 300 400 500 600 V VR(RMS) 35 70 105 140 210 280 350 420 V SYMBOL IF 4 A IFSM 125 A TJ -55 to +150 °C TSTG -55 to +150 °C 1 Version: G2105 SF41G – SF48G Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER Junction-to-ambient thermal resistance SYMBOL TYP UNIT RӨJA 25 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS SF41G SF42G SF43G SF44G SF45G SF46G SF47G SF48G (1) Reverse current @ rated VR TJ = 25°C (2) Junction capacitance IF = 4A, TJ = 25°C Reverse recovery time 1MHz, VR = 4.0V IF = 0.5A, IR = 1.0A, Irr = 0.25A TYP MAX UNIT - 1.0 V - 1.3 V - 1.7 V - 5 µA - 500 µA 100 - pF 80 - pF - 35 ns VF IR TJ = 125°C SF41G SF42G SF43G SF44G SF45G SF46G SF47G SF48G SYMBOL CJ trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SF4xG DO-201AD 1,250 / Tape & Reel SF4xG A0G DO-201AD 500 / Ammo box SF4xGH DO-201AD 1,250 / Tape & Reel SF4xGHA0G DO-201AD 500 / Ammo box Notes: 1. "x" defines voltage from 50V (SF41G) to 600V (SF48G) 2. “H” means AEC-Q101 qualified 2 Version: G2105 SF41G – SF48G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 4 CAPACITANCE (pF) 3 2 SF41G - SF44G 100 SF45G - SF48G 1 f=1.0MHz Vsig=50mVp-p 0 25 50 75 100 125 10 150 0.1 1 AMBIENT TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=100°C 10 1 TJ=25°C 0.1 30 40 50 60 70 80 90 100 1010 SF41G - SF44G UF1DLW 1 TJ=125°C TJ=25°C 10.1 SF45G - SF46G 0.01 SF47G - SF48G Pulse Pulse width width 300μs 300μs 1% 1% duty duty cycle cycle Pulse width 0.1 0.001 0.3 0.5 0.7 0.9 1.1 1.3 1.5 1.7 0.3 0.4 0.5 0.6 0.7 0.8 0.9 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 1.9 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 150 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (µA) Fig.4 Typical Forward Characteristics 100 20 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 (A) AVERAGE FORWARD CURRENT (A) 5 8.3ms single half sine wave 125 100 75 50 25 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: G2105 1.2 SF41G – SF48G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: G2105 SF41G – SF48G Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-201AD MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: G2105 SF41G – SF48G Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: G2105
SF46GHB0G 价格&库存
很抱歉,暂时无法提供与“SF46GHB0G”相匹配的价格&库存,您可以联系我们找货
