1N5821 B0G
1N5821 B0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-201AD
    DIODE SCHOTTKY 30V 3A DO201AD
1N5821 B0G 数据手册
1N5820 – 1N5822 Taiwan Semiconductor 3A, 20V - 40V Schottky Barrier Rectifier FEATURES ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Low forward voltage drop Guard ring for overvoltage protection High surge current capability RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converter PARAMETER VALUE UNIT IF 3 A VRRM 20 - 40 V IFSM 70 A TJ MAX 125 °C Package DO-201AD Configuration Single die MECHANICAL DATA ● ● ● ● ● ● Case: DO-201AD Molding compound meets UL 94V-0 flammability rating Terminal: Pure tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 1.10g (approximately) DO-201AD ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device 1N5820 1N5821 1N5822 1N5820 1N5821 1N5822 UNIT Repetitive peak reverse voltage VRRM 20 30 40 V Reverse voltage, total rms value VR(RMS) 14 21 28 V Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature IF 3 A IFSM 70 A TJ -55 to +125 °C Storage temperature TSTG -55 to +125 °C 1 Version: I2105 1N5820 – 1N5822 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER Junction-to-ambient thermal resistance SYMBOL TYP UNIT RӨJA 40 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL TYP MAX UNIT 0.475 V 0.500 V 0.525 V - 500 µA - 10 mA 200 - pF 1N5820 Forward voltage (1) 1N5821 IF = 3A, TJ = 25°C VF 1N5822 Reverse current @ rated VR (2) Junction capacitance TJ = 25°C IR TJ = 100°C 1MHz, VR = 4.0V CJ Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING 1N58x DO-201AD 1,250 / Tape & Reel 1N58x A0G DO-201AD 500 / Ammo box 1N58xH DO-201AD 1,250 / Tape & Reel 1N58xHA0G DO-201AD 500 / Ammo box Notes: 1. "x" defines voltage from 20V (1N5820) to 40V (1N5822) 2. “H” means AEC-Q101 qualified 2 Version: I2105 1N5820 – 1N5822 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 3 CAPACITANCE (pF) 2 1 100 f=1.0MHz Vsig=50mVp-p 10 0 25 50 75 100 0.1 125 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 1 TJ=75°C TJ=25°C 0.001 10 20 30 40 50 60 70 80 90 100 1010 UF1DLW 1 1N5820 TJ=125°C TJ=25°C 10.1 1N5821-1N5822 0.01 0.1 0.001 0.20.3 Pulse Pulse width width 300μs 300μs 1% duty cycle Pulse width 0.3 0.4 0.5 0.40.6 0.5 0.7 0.8 0.60.9 0.7 1 1.1 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig.5 Maximum Non-Repetitive Forward Surge Current 80 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 10 0.01 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 0.1 10 (A) AVERAGE FORWARD CURRENT (A) 4 70 8.3ms single half sine wave 60 50 40 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: I2105 1.2 1N5820 – 1N5822 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Characteristics TRANSIENT THERMAL IMPEDANCE (°C/W) 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 4 Version: I2105 1N5820 – 1N5822 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-201AD MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: I2105 1N5820 – 1N5822 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: I2105
1N5821 B0G 价格&库存
很抱歉,暂时无法提供与“1N5821 B0G”相匹配的价格&库存,您可以联系我们找货
