MUR160 – MUR190
Taiwan Semiconductor
1A, 600V - 900V High Efficient Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
High efficiency, Low VF
High efficient recovery time
175°C operating junction temperature
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
● DC to DC converter
● Switching mode converters and inverters
● Freewheeling application
PARAMETER
VALUE
UNIT
IF
1
A
VRRM
600 - 900
V
IFSM
35
A
TJ MAX
150 - 175
°C
Package
DO-204AC (DO-15)
Configuration
Single die
MECHANICAL DATA
Case: DO-204AC (DO-15)
Molding compound meets UL 94V-0 flammability rating
Terminal: Pure tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.400g (approximately)
DO-204AC (DO-15)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
MUR160
MUR190
MUR160
MUR190
UNIT
Repetitive peak reverse voltage
VRRM
600
900
V
Reverse voltage, total rms value
VR(RMS)
420
630
V
Forward current
Surge peak forward current, 8.3ms single half
sine wave superimposed on rated load
Junction temperature
IF
1
A
IFSM
35
A
TJ
-55 to +175
-55 to +150
°C
Storage temperature
TSTG
-55 to +175
-55 to +150
°C
1
Version: L2107
MUR160 – MUR190
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJA
50
°C/W
Junction-to-ambient thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
MUR160
Forward voltage
MUR190
(1)
MUR160
MUR190
Reverse current @ rated VR
Junction capacitance
Reverse recovery time
IF = 1A, TJ = 25°C
VF
IF = 1A, TJ = 150°C
TJ = 25°C
(2)
IR
TJ = 125°C
MUR160
MUR190
MUR160
MUR190
SYMBOL
1MHz, VR = 4.0V
CJ
IF = 0.5A, IR = 1.0A,
Irr = 0.25A
trr
TYP
MAX
UNIT
1.25
V
1.70
V
1.05
V
1.50
V
5
µA
150
µA
27
pF
15
pF
50
ns
75
ns
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
MUR1x
DO-204AC (DO-15)
3,500 / Tape & Reel
MUR1x A0G
DO-204AC (DO-15)
1,500 / Ammo box
MUR1xH
DO-204AC (DO-15)
3,500 / Tape & Reel
MUR1xHA0G
DO-204AC (DO-15)
1,500 / Ammo box
Notes:
1. "x" defines voltage from 600V (MUR160) to 900V (MUR190)
2. “H” means AEC-Q101 qualified
2
Version: L2107
MUR160 – MUR190
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
MUR160
CAPACITANCE (pF)
MUR160
1
MUR190
50
75
100
125
150
10
MUR190
f=1.0MHz
Vsig=50mVp-p
1
175
0.1
1
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
1
TJ=25°C
0.01
10
40
50
60
70
80
90
100
1010
UF1DLW
1
MUR160
TJ=125°C
TJ=25°C
10.1
MUR190
0.01
Pulse
Pulse width
width 300μs
300μs
1% duty cycle
Pulse width
0.1
0.001
0.5 0.7 0.9 1.1 1.3 1.5 1.7 1.9
0.3
0.4
0.5
0.6
0.7
0.8
0.9
2.1
1
1.1
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Fig.5 Maximum Non-Repetitive Forward Surge Current
40
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (µA)
Fig.4 Typical Forward Characteristics
100
0.1
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
10
10
(A)
AVERAGE FORWARD CURRENT (A)
2
35
8.3ms single half sine wave
30
25
10
5
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: L2107
1.2
MUR160 – MUR190
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: L2107
MUR160 – MUR190
PACKAGE OUTLINE DIMENSIONS
DO-204AC (DO-15)
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: L2107
MUR160 – MUR190
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: L2107
很抱歉,暂时无法提供与“MUR190HR0G”相匹配的价格&库存,您可以联系我们找货
