SR215HR0G
SR215HR0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-204AC
    DIODE SCHOTTKY 150V 2A DO204AC
SR215HR0G 数据手册
SR202 – SR220 Taiwan Semiconductor 2A, 20V - 200V Schottky Barrier Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Low forward voltage drop Low power loss, high efficiency Guard ring for overvoltage protection High surge current capability RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 2 A VRRM 20 - 200 V IFSM 50 A TJ MAX 125, 150 °C APPLICATIONS Package DO-204AC (DO-15) Configuration Single die ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converter MECHANICAL DATA ● ● ● ● ● ● Case: DO-204AC (DO-15) Molding compound meets UL 94V-0 flammability rating Terminal: Pure tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.400g (approximately) DO-204AC (DO-15) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Critical rate of rise of offstate voltage Junction temperature Storage temperature SR 202 SR 202 SR 203 SR 203 SR 204 SR 204 SR 205 SR 205 SR 206 SR 206 SR 209 SR 209 SR 210 SR 210 SR 215 SR 215 SR UNIT 220 SR 220 VRRM 20 30 40 50 60 90 100 150 200 V VR(RMS) 14 21 28 35 42 63 70 105 140 V SYMBOL IF 2 A IFSM 50 A dv/dt 10,000 V/µs TJ -55 to +125 TSTG -55 to +150 -55 to +150 1 °C °C Version: L2105 SR202 – SR220 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 21.7 °C/W Junction-to-ambient thermal resistance RӨJA 75.0 °C/W Junction-to-case thermal resistance RӨJC 14.0 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR (2) SR202 SR203 SR204 SR205 SR206 SR209 SR210 SR215 SR220 SR202 SR203 SR204 SR205 SR206 SR209 SR210 SR215 SR220 SR202 SR203 SR204 SR205 SR206 SR209 SR210 SR215 SR220 SR202 SR203 SR204 SR205 SR206 SR209 SR210 SR215 SR220 IF = 2A, TJ = 25°C SYMBOL VF TYP MAX UNIT - 0.55 V - 0.70 V - 0.85 V - 0.95 V - 500 µA - 100 µA - 10 mA - 5 mA - - mA - - mA - - mA - 2 mA TJ = 25°C TJ = 100°C IR TJ = 125°C Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms 2 Version: L2105 SR202 – SR220 Taiwan Semiconductor ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SR2x DO-204AC (DO-15) 3,500 / Tape & Reel SR2x A0G DO-204AC (DO-15) 1,500 / Ammo box SR2xH DO-204AC (DO-15) 3,500 / Tape & Reel SR2xHA0G DO-204AC (DO-15) 1,500 / Ammo box Notes: 1. "x" defines voltage from 20V (SR202) to 200V (SR220) 2. “H” means AEC-Q101 qualified 3 Version: L2105 SR202 – SR220 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 SR202-SR204 SR205 - SR220 CAPACITANCE (pF) 2 1 SR202 - SR204 SR205-SR206 SR209-SR220 100 f=1.0MHz Vsig=50mVp-p 10 0 25 50 75 100 125 1 150 10 LEAD TEMPERATURE (°C) REVERSE VOLTAGE (V) Fig.4 Typical Forward Characteristics INSTANTANEOUS FORWARD CURRENT (A) 100 SR202 - SR206 SR209 - SR220 TJ=125°C 1 0.1 TJ=75°C 0.01 TJ=25°C 0.001 10 20 30 40 50 60 70 80 90 100 10 10 SR202-SR204 UF1DLW 1 SR205-SR206 TJ=125°C TJ=25°C SR209-SR210 10.1 SR215-SR220 0.01 0.1 0.001 0.1 0.3 0.5 0.3 0.4 0.5 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% 1% duty duty cycle cycle Pulse width 0.7 0.6 0.9 0.7 1.1 0.8 1.3 0.9 1.5 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 60 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.3 Typical Reverse Characteristics 10 100 8.3ms single half sine wave 50 40 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 4 (A) AVERAGE FORWARD CURRENT (A) 3 Version: L2105 1.2 SR202 – SR220 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Characteristics TRANSIENT THERMAL IMPEDANCE (°C/W) 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 5 Version: L2105 SR202 – SR220 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-204AC (DO-15) MARKING DIAGRAM 6 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: L2105 SR202 – SR220 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 7 Version: L2105
SR215HR0G 价格&库存
很抱歉,暂时无法提供与“SR215HR0G”相匹配的价格&库存,您可以联系我们找货
