GP1607HC0G
GP1607HC0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-3
    DIODE ARRAY GP 16A TO220AB
GP1607HC0G 数据手册
GP1601 – GP1607 Taiwan Semiconductor 16A, 50V - 1000V Standard Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available High efficiency, low VF High current capability High surge current capability Low power loss RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 16 A VRRM 50 - 1000 V IFSM 150 A TJ MAX 150 °C Package TO-220AB Configuration Dual dies ● DC to DC converters ● Switching mode converters and inverters ● General purpose MECHANICAL DATA ● ● ● ● ● ● ● Case: TO-220AB Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.82g (approximately) TO-220AB ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) GP GP GP PARAMETER SYMBOL 1601 1602 1603 GP GP GP Marking code on the device 1601 1602 1603 Repetitive peak reverse voltage VRRM 50 100 200 Reverse voltage, total rms value VR(RMS) 35 70 140 GP 1604 GP 1604 400 GP 1605 GP 1605 600 GP 1606 GP 1606 800 280 420 560 GP UNIT 1607 GP 1607 1000 V 700 V Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature IF 16 A IFSM 150 A TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C 1 Version: G2104 GP1601 – GP1607 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER Junction-to-case thermal resistance SYMBOL TYP UNIT RӨJC 1.5 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage per diode CONDITIONS (1) Reverse current @ rated VR per diode Junction capacitance per diode IF = 8A, TJ = 25°C (2) TJ = 25°C SYMBOL TYP MAX UNIT VF - 1.1 V - 10 µA - 250 µA 50 - pF IR TJ = 125°C 1MHz, VR = 4.0V CJ Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING GP16x TO-220AB 50 / Tube GP16xH TO-220AB 50 / Tube Notes: 1. “x” defines voltage from 50V(GP1601) to 1000V(GP1607) 2. “H” means AEC-Q101 qualified 2 Version: G2104 GP1601 – GP1607 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 16 CAPACITANCE (pF) 12 8 100 10 4 f=1.0MHz Vsig=50mVp-p 1 0 25 50 75 100 125 1 150 10 CASE TEMPERATURE (°C) REVERSE VOLTAGE (V) Fig.4 Typical Forward Characteristics INSTANTANEOUS FORWARD CURRENT (A) 10 TJ=125°C 1 TJ=25°C 0.1 20 30 40 50 60 70 80 90 100 100 10 10 UF1DLW 1 TJ=125°C TJ=25°C 0.1 1 0.01 0.1 0.001 0.6 Pulse width 300μs 1% duty cycle Pulse width 0.3 0.8 0.4 1.0 0.5 1.2 1.4 0.6 0.7 0.8 1.6 0.9 1.8 1 1.1 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig.5 Maximum Non-Repetitive Forward Surge Current 175 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (µA) Fig.3 Typical Reverse Characteristics 10 100 (A) AVERAGE FORWARD CURRENT (A) 20 150 8.3ms single half sine wave 125 100 75 50 25 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: G2104 1.2 GP1601 – GP1607 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-220AB MARKING DIAGRAM 4 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: G2104 GP1601 – GP1607 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: G2104
GP1607HC0G 价格&库存
很抱歉,暂时无法提供与“GP1607HC0G”相匹配的价格&库存,您可以联系我们找货
