UF4007HR1G
UF4007HR1G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-204AL
    DIODE GEN PURP 1A DO204AL
UF4007HR1G 数据手册
UF4001 – UF4007 Taiwan Semiconductor 1A, 50V - 1000V High Efficient Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Glass passivated chip junction Excellent high temperature switching High efficiency, low VF Ultrafast recovery time for high efficiency RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 1 A VRRM 50 - 1000 V IFSM 30 A TJ MAX 150 °C Package DO-204AL (DO-41) Configuration Single die ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● Case: DO-204AL (DO-41) Molding compound meets UL 94V-0 flammability rating Terminal: Pure tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.330g (approximately) DO-204AL (DO-41) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature Storage temperature SYMBOL UF 4001 UF 4002 UF 4003 UF 4004 UF 4005 UF 4006 UF UNIT 4007 UF4001 UF4002 UF4003 UF4004 UF4005 UF4006 UF4007 VRRM 50 100 200 400 600 800 1000 V VR(RMS) 35 70 140 280 420 560 700 V IF 1 A IFSM 30 A TJ -55 to +150 °C TSTG -55 to +150 °C 1 Version: P2104 UF4001 – UF4007 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 15 °C/W Junction-to-ambient thermal resistance RӨJA 60 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS UF4001 UF4002 UF4003 UF4004 UF4005 UF4006 UF4007 (1) Reverse current @ rated VR TJ = 25°C (2) 1MHz, VR = 4.0V UF4001 UF4002 UF4003 UF4004 UF4005 UF4006 UF4007 IF = 0.5A, IR = 1.0A, Irr = 0.25A TYP MAX UNIT - 1.0 V - 1.7 V - 5 µA - 150 µA 17 - pF - 50 ns - 75 ns VF IR TJ = 125°C Junction capacitance Reverse recovery time IF = 1A, TJ = 25°C SYMBOL CJ trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING UF400x DO-204AL (DO-41) 5,000 / Tape & Reel UF400x A0G DO-204AL (DO-41) 3,000 / Ammo box UF400xH DO-204AL (DO-41) 5,000 / Tape & Reel UF400xHA0G DO-204AL (DO-41) 3,000 / Ammo box Notes: 1. “x” defines voltage from 50V (UF4001) to 1000V (UF4007) 2. “H” means AEC-Q101 qualified 2 Version: P2104 UF4001 – UF4007 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 CAPACITANCE (pF) 1 0 25 50 75 100 125 10 f=1.0MHz Vsig=50mVp-p 1 150 0.1 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 100 10 TJ=25°C 1 0.1 10 20 30 40 50 60 70 80 100 Fig.4 Typical Forward Characteristics 1000 90 100 10 10 UF4001-UF4004 UF1DLW 1 TJ=125°C TJ=25°C 10.1 0.01 0.1 0.001 0.6 UF4005-UF4007 Pulse width 300μs 1% duty cycle Pulse width 0.3 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 0.8 0.4 1.0 0.5 1.2 1.4 0.6 0.7 0.8 1.6 0.9 1.8 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 35 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (µA) Fig.3 Typical Reverse Characteristics UF4001-UF4004 UF4005-UF4007 10 REVERSE VOLTAGE (V) (A) AVERAGE FORWARD CURRENT (A) 2 30 8.3ms single half sine wave 25 20 15 10 5 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: P2104 1.2 UF4001 – UF4007 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: P2104 UF4001 – UF4007 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-204AL (DO-41) MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: P2104 UF4001 – UF4007 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: P2104
UF4007HR1G 价格&库存
很抱歉,暂时无法提供与“UF4007HR1G”相匹配的价格&库存,您可以联系我们找货
