GBL201 – GBL207
Taiwan Semiconductor
2A, 50V - 1000V Standard Bridge Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Glass passivated chip junction
Ideal for printed circuit board
High case dielectric strength
Typical IR less than 0.1μA
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
2
A
VRRM
50 - 1000
V
IFSM
60
A
TJ MAX
150
°C
Package
GBL
Configuration
Quad
APPLICATIONS
● Switching mode power supply (SMPS)
● Adapters
● Lighting application
MECHANICAL DATA
Case: GBL
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 2.00g (approximately)
GBL
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Repetitive peak reverse voltage
VRRM
GBL
201
GBL
201
50
Reverse voltage, total rms value
VR(RMS)
35
PARAMETER
SYMBOL
Marking code on the device
Forward current
Surge peak forward current,
8.3ms single half sine-wave
superimposed on rated load
Rating for fusing (t
很抱歉,暂时无法提供与“GBL203 D2G”相匹配的价格&库存,您可以联系我们找货
