SFAS801G MNG
SFAS801G MNG
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-263(D²Pak)
    耐压:50V 电流:8A 反向恢复时间:35ns
SFAS801G MNG 数据手册
SFAS801G - SFAS808G Taiwan Semiconductor CREAT BY ART 8A, 50V - 600V Surface Mount Super Fast Rectifiers FEATURES - Glass passivated junction chip - Ideal for automated placement - High efficiency, low VF - High surge current capability - Low power loss - Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC - Halogen-free according to IEC 61249-2-21 2 TO-263AB (D PAK) MECHANICAL DATA Case: TO-263AB (D2PAK) Molding compound, UL flammability classification rating 94V-0 Moisture sensitivity level: level 1, per J-STD-020 Part no. with suffix "H" means AEC-Q101 qualified Packing code with suffix "G" means green compound (halogen-free) Terminal: Matte tin plated leads, solderable per JESD22-B102 Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.33 g (approximately) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted) PARAMETER SYMBOL SFAS SFAS SFAS SFAS SFAS SFAS SFAS SFAS 801G 802G 803G 804G 805G 806G 807G 808G UNIT Maximum repetitive peak reverse voltage VRRM 50 100 150 200 300 400 500 600 V Maximum RMS voltage VRMS 35 70 105 140 210 280 350 420 V Maximum DC blocking voltage VDC 50 100 150 200 300 400 500 600 V Maximum average forward rectified current IF(AV) 8 A Peak forward surge current, 8.3 ms single half sine-wave superimposed on rated load IFSM 125 A Maximum instantaneous forward voltage IF= 8 A Maximum reverse current @ rated VR VF TJ=25°C TJ=100°C trr Typical junction capacitance (Note 2) CJ Operating junction temperature range Storage temperature range 1.3 1.7 10 IR Maximum reverse recovery time (Note 1) Typical thermal resistance 0.95 μA 400 35 80 V ns 60 pF RθJC 2.2 °C/W TJ - 55 to +150 °C TSTG - 55 to +150 °C Note 1: Reverse Recovery Test Conditions: IF=0.5A, IR=1.0A, IRR=0.25A Note 2: Measured at 1 MHz and Applied Reverse Voltage of 4.0V D.C. Document Number: DS_D1405074 Version: M15 SFAS801G - SFAS808G Taiwan Semiconductor ORDERING INFORMATION PART NO. PART NO. PACKING CODE PACKING CODE SUFFIX SFAS80xG (Note 1) SUFFIX RN H PACKAGE 800 / 13" Paper reel D2PAK G MN PACKING (*) 800 / 13" Plastic reel Note 1: "x" defines voltage from 50V (SFAS801G) to 600V (SFAS808G) *: Optional available EXAMPLE PREFERRED P/N PART NO. SFAS801GHRNG SFAS801G PART NO. PACKING CODE PACKING CODE SUFFIX H DESCRIPTION SUFFIX RN AEC-Q101 qualified Green compound G RATINGS AND CHARACTERISTICS CURVES (TA=25℃ unless otherwise noted) FIG. 2 TYPICAL REVERSE CHARACTERISTICS FIG.1 FORWARD CURRENT DERATING CURVE AVERAGE FORWARD A CURRENT (A) 8 6 4 RESISTIVE OR INDUCTIVELOAD WITH HEATSINK 2 0 0 25 50 75 100 125 150 INSTANTANEOUS REVERSE CURRENT (μA) 1000 10 100 10 1 0 90 60 30 0 100 INSTANTANEOUS FORWARD CURRENT (A) PEAK FORWARD SURGE CURRENT (A) 8.3ms Single Half Sine Wave NUMBER OF CYCLES AT 60 Hz 40 60 80 100 120 140 FIG. 5 TYPICAL FORWARD CHARACTERISTICS 150 10 20 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) FIG. 3 MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT 1 TJ=25°C 0.1 CASE TEMPERATURE (oC) 120 TJ=100°C 100 SFAS801G-SFAS804G 10 SFAS805G-SFAS806G 1 SFAS807G-SFAS808G Pulse Width=300μs 1% Duty Cycle 0.1 0.4 0.6 0.8 1 1.2 1.4 1.6 1.8 FORWARD VOLTAGE (V) Document Number: DS_D1405074 Version: M15 SFAS801G - SFAS808G Taiwan Semiconductor FIG. 5 TYPICAL JUNCTION CAPACITANCE 100 f=1.0MHz Vsig=50mVp-p CAPACITANCE (pF) 90 80 70 60 SFAS801G-SFAS804G 50 SFAS805G-SFAS808G 40 1 10 100 1000 REVERSE VOLTAGE (V) PACKAGE OUTLINE DIMENSIONS TO-263AB (D2PAK) DIM. Unit (mm) Unit (inch) Min Max Min Max A - 10.5 - 0.413 B 14.60 15.88 0.575 0.625 C 2.41 2.67 0.095 0.105 D 0.68 0.94 0.027 0.037 E 2.29 2.79 0.090 0.110 F 4.44 4.70 0.175 0.185 G 1.14 1.40 0.045 0.055 H 1.14 1.40 0.045 0.055 I 8.25 9.25 0.325 0.364 J 0.36 0.53 0.014 0.021 K 2.03 2.79 0.080 0.110 SUGGESTED PAD LAYOUT Symbol Unit (mm) Unit (inch) A 10.8 0.425 B 8.3 0.327 C 1.1 0.043 D 3.5 0.138 E 16.9 0.665 F 9.5 0.374 G 2.5 0.098 MARKING DIAGRAM P/N = Specific Device Code G = Green Compound YWW = Date Code F = Factory Code Document Number: DS_D1405074 Version: M15 SFAS801G - SFAS808G Taiwan Semiconductor CREAT BY ART Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Document Number: DS_D1405074 Version: M15
SFAS801G MNG 价格&库存
很抱歉,暂时无法提供与“SFAS801G MNG”相匹配的价格&库存,您可以联系我们找货
SFAS801G MNG
  • 1+3.88800
  • 10+3.08880
  • 30+2.74320
库存:1
