TS50P06G C2G
TS50P06G C2G
    TAIWANSEMICONDUCTOR(台湾半导体)
    SIP4
    BRIDGE RECT 1P 800V 50A TS-6P
TS50P06G C2G 数据手册
TS50P05G – TS50P07G Taiwan Semiconductor 50A, 600V - 1000V Standard Bridge Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Glass passivated chip junction Ideal for printed circuit board Typical IR less than 0.1μA High surge current capability UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 50 A VRRM 600 - 1000 V IFSM 400 A TJ MAX 150 °C Package TS-6P Configuration Quad APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● Lighting application MECHANICAL DATA ● ● ● ● ● ● ● Case: TS-6P Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Mounting torque: 0.92 N⋅m maximum Polarity: As marked Weight: 7.15g (approximately) TS-6P ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device TS50P05G TS50P06G TS50P07G TS50P05G TS50P06G TS50P07G UNIT Repetitive peak reverse voltage VRRM 600 800 1000 V Reverse voltage, total rms value VR(RMS) 420 560 700 V Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Rating of fusing (t
TS50P06G C2G 价格&库存
很抱歉,暂时无法提供与“TS50P06G C2G”相匹配的价格&库存,您可以联系我们找货
