TST20L60CW C0G
TST20L60CW C0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-3
    DIODE SCHOTTKY 60V 10A TO220AB
TST20L60CW C0G 数据手册
TST20L60CW Taiwan Semiconductor 20A, 60V Trench Schottky Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Patented Trench Schottky technology Excellent high temperature stability Low forward voltage Low power loss/ High efficiency High forward surge capability RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 20 A VRRM 60 V IFSM 120 A TJ MAX 150 °C Package TO-220AB Configuration Dual dies ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converters MECHANICAL DATA ● ● ● ● ● ● ● Case: TO-220AB Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 1A whisker test Polarity: As marked Weight: 1.88g (approximately) TO-220AB ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device TST20L60CW UNIT TST20L60CW Repetitive peak reverse voltage VRRM 60 V Reverse voltage, total rms value VR(RMS) 42 V IF 20 A IFSM 120 A dv/dt 10,000 V/μs Junction temperature TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Critical rate of rise of off-state voltage 1 Version: C2104 TST20L60CW Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 3 °C/W Junction-to-case thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL IF = 10A, TJ = 25°C Forward voltage per diode IF = 20A, TJ = 25°C (1) IF = 10A, TJ = 125°C VF IF = 20A, TJ = 125°C Reverse current @ rated VR per diode (2) TJ = 25°C TJ = 125°C IR TYP MAX UNIT 0.56 0.65 V 0.69 0.78 V 0.52 0.61 V 0.67 0.76 V - 500 µA - 50 mA Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE PACKAGE PACKING TST20L60CW TO-220AB 50 / Tube 2 Version: C2104 TST20L60CW Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 20 CAPACITANCE (pF) 15 10 1000 100 5 f=1.0MHz Vsig=50mVp-p 0 25 50 75 100 125 10 0.10 150 1.00 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 100 TJ=150°C 10 TJ=125°C TJ=100°C 0.1 0.01 TJ=25°C 0.001 10 20 30 40 50 60 70 80 100.00 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 1 10.00 90 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 100 10 10 1 UF1DLW TT J=150°C J=125°C 0.1 1 0.01 TJ=25°C (A) AVERAGE FORWARD CURRENT (A) 25 TJ=125°C TJ=100°C TJ=25°C Pulse width 300μs 1% duty cycle Pulse width 0.1 0.001 0.0 0.30.1 0.40.2 0.50.3 0.60.4 0.7 0.5 0.8 0.6 0.9 0.7 10.8 1.1 FORWARD VOLTAGE (V) 3 Version: C2104 1.2 TST20L60CW Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-220AB MARKING DIAGRAM 4 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: C2104 TST20L60CW Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: C2104
TST20L60CW C0G 价格&库存
很抱歉,暂时无法提供与“TST20L60CW C0G”相匹配的价格&库存,您可以联系我们找货
