TPMR10G S1G
TPMR10G S1G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-277
    DIODE GEN PURP 400V 10A TO277A
TPMR10G S1G 数据手册
TPMR10D – TPMR10J Taiwan Semiconductor 10A, 200V - 600V Super Fast Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● ● ● KEY PARAMETERS Very low profile, typical height of 1.1mm 175°C operating junction temperature Glass passivated chip junction Low conduction loss Low leakage current High forward surge capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 10 A VRRM 200 - 600 V IFSM 150 A TJ MAX 175 °C Package TO-277A (SMPC) Configuration Single die APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● Case: TO-277A (SMPC) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.095g (approximately) TO-277A (SMPC) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device TPMR10D TPMR10G TPMR10J UNIT MR10D MR10G MR10J Repetitive peak reverse voltage VRRM 200 400 600 V Reverse voltage, total rms value VR(RMS) 140 280 420 V Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature IF 10 A IFSM 150 A TJ -55 to +175 °C Storage temperature TSTG -55 to +175 °C 1 Version: C2103 TPMR10D – TPMR10J Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER Junction-to-lead thermal resistance SYMBOL TYP UNIT RӨJL 8.4 °C/W RӨJA 78 °C/W (1) Junction-to-ambient thermal resistance (2) Notes: 1. Mounted on FR4 PCB with 16mm x 16mm Cu pad area 2. Free air, mounted on recommended pad ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL TPMR10D TPMR10G Forward voltage IF = 10A, TJ = 25°C TPMR10J (1) VF TPMR10D TPMR10G IF = 10A, TJ = 125°C TPMR10J Reverse current @ rated VR (2) TPMR10D TPMR10G TPMR10J TPMR10D TPMR10G TPMR10J Junction capacitance Reverse recovery time TPMR10D TPMR10G TPMR10J TPMR10D TPMR10G TPMR10J TJ = 25°C IR TJ = 125°C 1MHz, VR = 4.0V CJ IF = 0.5A, IR = 1.0A Irr = 0.25A trr IF = 1A, di/dt = -50A/μs VR = 30V trr TYP MAX UNIT - 0.95 V - 1.20 V - 1.80 V - 0.86 V - 1.00 V - - V - 5 µA - 10 µA - 250 µA - 500 µA 140 - pF - 35 ns - 40 ns - 60 ns - - ns Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING TPMR10x TO-277A (SMPC) 6,000 / Tape & Reel Notes: 1. “x” defines voltage from 200V(TPMR10D) to 600V(TPMR10J) 2 Version: C2103 TPMR10D – TPMR10J Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 10 CAPACITANCE (pF) 8 6 4 100 2 0 25 50 75 100 125 150 f=1.0MHz Vsig=50mVp-p 10 175 0.1 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 1 TJ=25°C 10 20 30 40 50 60 70 80 100 Fig.4 Typical Forward Characteristics 10 90 100 100 10 10 1 TPMR10D TPMR10G TPMR10J UF1DLW TJ=125°C TJ=25°C 0.1 TJ=125°C 1 0.01 0.1 0.001 0.2 TJ=25°C 0.4 0.6 0.8 0.3 0.4 0.5 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% duty cycle Pulse width 1.0 1.2 1.4 1.6 1.8 0.6 0.7 0.8 0.9 2.0 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 175 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.3 Typical Reverse Characteristics 0.1 10 REVERSE VOLTAGE (V) (A) AVERAGE FORWARD CURRENT (A) 12 150 8.3ms single half sine wave 125 100 75 50 25 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: C2103 1.2 TPMR10D – TPMR10J Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: C2103 TPMR10D – TPMR10J Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-277A (SMPC) SUGGESTED PAD LAYOUT MARKING DIAGRAM P/N YW F 5 = Marking Code = Date Code = Factory Code Version: C2103 TPMR10D – TPMR10J Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: C2103
TPMR10G S1G 价格&库存
很抱歉,暂时无法提供与“TPMR10G S1G”相匹配的价格&库存,您可以联系我们找货
