RS3DB-T – RS3MB-T
Taiwan Semiconductor
3A, 200V - 1000V Fast Recovery Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Glass passivated chip junction
Ideal for automated placement
Low reverse leakage
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
● DC to DC converter
● Switching mode converters and inverters
● General purpose
PARAMETER
VALUE
UNIT
IF
3
A
VRRM
200 - 1000
V
IFSM
80
A
TJ MAX
150
°C
Package
DO-214AA (SMB)
Configuration
Single die
MECHANICAL DATA
Case: DO-214AA (SMB)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 1 whisker test
Polarity: Indicated by cathode band
Weight: 0.090g (approximately)
DO-214AA (SMB)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL RS3DB-T RS3GB-T RS3JB-T RS3KB-T RS3MB-T UNIT
Marking code on the device
Repetitive peak reverse voltage
Reverse voltage, total rms
value
Forward current
Surge peak forward
t = 8.3ms
current single half
sine-wave
superimposed on
t = 1.0ms
rated load
Junction temperature
Storage temperature
RS3DB
RS3GB
RS3JB
RS3KB
RS3MB
VRRM
200
400
600
800
1000
V
VR(RMS)
140
280
420
560
700
V
IF
3
A
80
A
224
A
TJ
-55 to +150
°C
TSTG
-55 to +150
°C
IFSM
1
Version: C2102
RS3DB-T – RS3MB-T
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
°C/W
Junction-to-ambient thermal resistance
RӨJA
78
°C/W
Junction-to-case thermal resistance
RӨJC
26
°C/W
Thermal Performance Note: Units mounted on PCB (10mm x 10mm Cu pad test board)
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
TYP
MAX
UNIT
0.94
V
1.02
1.30
V
0.78
V
IF = 3.0A, TJ =125°C
0.87
1.17
V
IF = 1.5A, TJ = 25°C
0.99
V
1.10
1.30
V
0.80
V
0.90
1.16
V
1.03
V
1.13
1.30
V
0.83
V
0.94
1.14
V
5
µA
150
µA
150
ns
250
ns
500
ns
50
pF
RS3DB-T
RS3GB-T
(1)
Forward voltage
RS3JB-T
IF = 3.0A, TJ = 25°C
IF = 1.5A, TJ = 125°C
RS3KB-T IF = 3.0A, TJ = 25°C
RS3MB-T IF = 1.5A, TJ = 125°C
VF
VF
VF
Reverse current @ rated VR
(2)
Reverse recovery time
Junction capacitance
TJ = 25°C
TJ = 125°C
RS3DB-T
RS3GB-T
I = 0.5A, IR = 1.0A
RS3JB-T F
Irr = 0.25A
RS3KB-T
RS3MB-T
1MHz, VR = 4.0V
IR
trr
CJ
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
RS3xB-T
DO-214AA (SMB)
3,000 / Tape & Reel
Notes:
1. “x” defines voltage from 200V(RS3DB-T) to 1000V(RS3MB-T)
2
Version: C2102
RS3DB-T – RS3MB-T
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
3
CAPACITANCE (pF)
2
1
10
RS3DB-T to RS3GB-T
RS3JB-T
RS3KB-T - RS3MB-T
f=1.0MHz
Vsig=50mVp-p
75
100
125
1
150
1
10
LEAD TEMPERATURE (°C)
Fig.4 Typical Forward Characteristics
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.3 Typical Reverse Characteristics
1000
RS3DB-T – RS3GB-T
100
TJ=150°C
10
1
TJ=125°C
0.1
0.01
TJ=25°C
0.001
TJ=-55°C
0.0001
10
40
50
60
70
80
90 100
10 10
RS3DB-T – RS3GB-T
UF1DLW
TJ=150°C
1
TJ=125°C
TJ=125°C
TJ=-55°C
0.01
0.001
0.1
0.40.3
Pulse width 300μs
Pulse width
1% duty cycle
0.4
0.6
TJ=150°C
TJ=125°C
1
0.1
TJ=25°C
0.01
TJ=-55°C
0.001
10
40
50
60
70
80
90
0.7
1
0.8 1.20.9
11.4
1.1
1.2
1
1.1
1.6
1.2
Fig.6 Typical Forward Characteristics
1000
10
0.5 0.80.6
FORWARD VOLTAGE (V)
Fig.5 Typical Reverse Characteristics
100
TJ=25°CTJ=25°C
10.1
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
RS3JB-T
100
REVERSE VOLTAGE (V)
(A)
25
100
10
10
RS3JB-T
UF1DLW
T =150°C
1
J
TJ=125°C
TJ=125°C
TJ=25°C
0.1
1
TJ=25°C
0.01
0.001
0.1
0.3
0.4
(A)
AVERAGE FORWARD CURRENT (A)
4
TJ=-55°C
Pulse
width
Pulse width
300μs
1% duty cycle
0.4
0.6
0.5
0.8
0.6
1
0.7
0.8
1.2
0.9
1.4
FORWARD VOLTAGE (V)
3
Version: C2102
RS3DB-T – RS3MB-T
TJ=150°C
100
10
TJ=125°C
1
TJ=25°C
0.1
0.01
TJ=-55°C
0.001
10
40
50
60
70
80
90
100
10
10
RS3KB-T – RS3MB-T
UF1DLW
TJ=150°C
1
0.1
1
T =125°C
TJ=125°CJ
TJ=25°C
TJ=25°C
(A)
RS3KB-T – RS3MB-T
Fig.8 Typical Forward Characteristics
1000
TJ=-55°C
0.01
0.001
0.1
0.3
0.4
Pulse widthPulse
300μs
width
1% duty cycle
0.4
0.6
0.5
0.8
0.6
1
0.7
0.8
1.2
0.9
1.4
1
1.6
1.1
FORWARD VOLTAGE (V)
Fig.9 Typical Transient Thermal Impedance
100
TRANSIENT THERMAL IMPEDANCE (°C/W)
Fig.7 Typical Reverse Characteristics
10
1
0.1
0.01
0.001
0.000001
0.00001
0.0001
0.001
0.01
0.1
1
10
100
PULSE DURATION (s)
4
Version: C2102
1.2
RS3DB-T – RS3MB-T
PACKAGE OUTLINE DIMENSIONS
DO-214AA (SMB)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: C2102
RS3DB-T – RS3MB-T
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: C2102
很抱歉,暂时无法提供与“RS3KB-T R5G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 850+1.57496850+0.20377
- 1700+1.417851700+0.18344
- 2550+1.337692550+0.17307
- 4250+1.247594250+0.16141
- 5950+1.194225950+0.15451
- 8500+1.142328500+0.14779
- 国内价格 香港价格
- 1+5.742221+0.74291
- 10+3.5574010+0.46025
- 100+2.26935100+0.29360
- 国内价格
- 1+1.22904
- 200+0.49043
- 500+0.47402
- 850+0.46592
