MUR305S – MUR360S
Taiwan Semiconductor
3A, 50V - 600V Ultra Fast Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Glass passivated chip junction
Ideal for automated placement
Ultra Fast recovery time for high efficiency
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
3
A
VRRM
50 - 600
V
IFSM
75
A
TJ MAX
175
°C
APPLICATIONS
● High frequency rectification
● Freewheeling application
● Switching mode converters and inverters in computer, and
telecommunication
Package
DO-214AB (SMC)
Configuration
Single die
MECHANICAL DATA
Case: DO-214AB (SMC)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.210g (approximately)
DO-214AB (SMC)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Repetitive peak reverse voltage
VRRM
MUR
305S
MUR
305S
50
Reverse voltage, total rms value
VR(RMS)
35
PARAMETER
SYMBOL
Marking code on the device
MUR
310S
MUR
310S
100
MUR
315S
MUR
315S
150
MUR
320S
MUR
320S
200
MUR
340S
MUR
340S
400
MUR
360S
MUR
360S
600
70
105
140
280
420
UNIT
V
V
Forward current
Peak forward surge current,
8.3ms single half sine-wave
superimposed on rated load
Junction temperature
IF
3
A
IFSM
75
A
TJ
- 55 to +175
°C
Storage temperature
TSTG
- 55 to +175
°C
1
Version: I2102
MUR305S – MUR360S
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJL
11
°C/W
Junction-to-lead thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
(2)
Reverse recovery time
MUR305S
MUR310S
MUR315S
MUR320S
MUR340S
MUR360S
MUR305S
MUR310S
MUR315S
MUR320S
MUR340S
MUR360S
MUR305S
MUR310S
MUR315S
MUR320S
MUR340S
MUR360S
MUR305S
MUR310S
MUR315S
MUR320S
MUR340S
MUR360S
MUR305S
MUR310S
MUR315S
MUR320S
MUR340S
MUR360S
IF = 3A, TJ = 25°C
IF = 3A, TJ = 150°C
TJ = 25°C
TJ = 150°C
IF = 0.5A, IR = 1.0A
Irr = 0.25A
SYMBOL
TYP
MAX
UNIT
0.875
V
1.250
V
0.710
V
1.050
V
5
μA
10
μA
150
μA
250
μA
25
ns
50
ns
VF
VF
IR
IR
trr
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
MUR3xS
DO-214AB (SMC)
3,000 / Tape & Reel
Notes:
1. “x” defines voltage from 50V(MUR305S) to 600V(MUR360S)
2
Version: I2102
MUR305S – MUR360S
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
3
CAPACITANCE (pF)
2
1
100
MUR305S - MUR320S
MUR340S - MUR360S
f=1.0MHz
Vsig=50mVp-p
10
75
100
125
150
0.1
175
1
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.4 Typical Forward Characteristics
100
MUR305S - MUR320S
10
TJ=150°C
0.1
0.01
TJ=25°C
0.001
10
40
50
60
70
80
90
100
10 10
MUR305S - MUR320S
UF1DLW
1
TJ=150°C
TJ=125°C
TJ=25°C
0.01
Pulse width 300μs
1% duty cycle
Pulse width
0.1
0.001
0.0 0.2 0.4 0.6 0.8 1.0 1.2
0.3
0.4
0.5
0.6
0.7
0.8
MUR340S - MUR360S
10
TJ=150°C
1
0.1
TJ=25°C
0.001
30
40
50
60
70
80
90
1.6
1
1.1
1.2
1.1
1.2
Fig.6 Typical Forward Characteristics
100
0.9
FORWARD VOLTAGE (V)
Fig.5 Typical Reverse Characteristics
10
TJ=25°C
1
0.1
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
0.01
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
1
10
(A)
25
100
10 10
MUR340S - MUR360S
1
1
0.1
UF1DLW
TJ=150°C
TJ=125°C
TJ=25°C
(A)
AVERAGE FORWARD CURRENT (A)
4
TJ=25°C
0.01
0.1
0.001
0.4
0.3
Pulse width 300μs
1% duty cycle
Pulse width
0.6
0.4
0.5
0.8
0.6
1.0
0.7
0.8
1.2
0.9
1.4
1
FORWARD VOLTAGE (V)
3
Version: I2102
MUR305S – MUR360S
Fig.7 Maximum Non-Repetitive Forward Surge Current
PEAK FORWARD SURGE CURRENT (A)
90
8.3ms single half sine wave
75
60
45
30
15
10
100
NUMBER OF CYCLES AT 60 Hz
4
Version: I2102
MUR305S – MUR360S
PACKAGE OUTLINE DIMENSIONS
DO-214AB (SMC)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: I2102
MUR305S – MUR360S
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: I2102
很抱歉,暂时无法提供与“MUR315S V7G”相匹配的价格&库存,您可以联系我们找货
