SRAF1630 C0G
SRAF1630 C0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-2
    DIODE SCHOTTKY 30V 16A ITO220AC
SRAF1630 C0G 数据手册
SRAF1620 – SRAF16100 Taiwan Semiconductor 16A, 20V - 100V Schottky Barrier Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Low power loss, high efficiency Guard ring for over-voltage protection High surge current capability UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 16 A VRRM 20 - 100 V IFSM 275 A TJ MAX 125, 150 °C Package ITO-220AC Configuration Single die ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converter MECHANICAL DATA ● ● ● ● ● ● ● Case: ITO-220AC Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.70g (approximately) ITO-220AC ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device Repetitive peak revers voltage VRRM Reverse voltage total rms value VR(RMS) Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Critical rate of rise of off-state voltage Junction temperature Storage temperature SRAF SRAF SRAF SRAF SRAF SRAF SRAF UNIT 1620 1630 1640 1650 1660 1690 16100 SRAF SRAF SRAF SRAF SRAF SRAF SRAF 1620 1630 1640 1650 1660 1690 16100 20 30 40 50 60 90 100 V 14 21 28 35 42 63 70 V IF 16 A IFSM 275 A dv/dt 10,000 V/µs TJ -55 to +125 TSTG -55 to +150 -55 to +150 1 °C °C Version: J2105 SRAF1620 – SRAF16100 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 4 °C/W Junction-to-case resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR (2) SRAF1620 SRAF1630 SRAF1640 SRAF1650 SRAF1660 SRAF1690 SRAF16100 SRAF1620 SRAF1630 SRAF1640 SRAF1650 SRAF1660 SRAF1690 SRAF16100 SRAF1620 SRAF1630 SRAF1640 SRAF1650 SRAF1660 SRAF1690 SRAF16100 SRAF1620 SRAF1630 SRAF1640 SRAF1650 SRAF1660 SRAF1690 SRAF16100 IF = 16A, TJ = 25°C SYMBOL VF TYP MAX UNIT - 0.55 V - 0.70 V - 0.92 V - 500 µA - 100 µA - 15 mA - 10 mA - - mA - - mA - 5 mA TJ = 25°C TJ = 100°C IR TJ = 125°C Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SRAF16x ITO-220AC 50 / Tube SRAF16xH ITO-220AC 50 / Tube Notes: 1. “x” defines voltage from 20V(SRAF1620) to 100V(SRAF16100) 2. “H” means AEC-Q101 qualified 2 Version: J2105 SRAF1620 – SRAF16100 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 SRAF1650-16100 16 CAPACITANCE (pF) AVERAGE FORWARD CURRENT (A) 20 12 SRAF1620-1640 8 SRAF1620-1640 1000 SRAF1650-16100 4 f=1.0MHz Vsig=50mVp-p 100 0 25 50 75 100 125 0.1 150 1 CASE TEMPERATURE (°C) 1 TJ=75°C 0.1 TJ=25°C 0.01 30 40 50 60 70 80 90 100 100 10 SRAF1620-1640 1 UF1DLW SRAF1650-1660 10 TJ=125°C TJ=25°C 0.1 (A) INSTANTANEOUS FORWARD CURRENT (A) TJ=100°C 1 0.01 SRAF1690-16100 0.1 0.001 0.10.30.2 0.4 0.3 0.5 0.4 Pulse width 300μs Pulse width 1% duty cycle 0.5 0.6 0.6 0.7 0.70.8 0.80.90.9 1 1 1.1 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig.5 Maximum Non-Repetitive Forward Surge Current 300 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 10 20 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 275 250 225 200 175 150 125 100 75 50 25 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: J2105 1.2 SRAF1620 – SRAF16100 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Characteristics TRANSIENT THERMAL IMPEDANCE (°C/W) 100 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 4 Version: J2105 SRAF1620 – SRAF16100 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS ITO-220AC MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: J2105 SRAF1620 – SRAF16100 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: J2105
SRAF1630 C0G 价格&库存
很抱歉,暂时无法提供与“SRAF1630 C0G”相匹配的价格&库存,您可以联系我们找货
