ABS15JHRGG
ABS15JHRGG
    TAIWANSEMICONDUCTOR(台半)
    SMD4
    BRIDGE RECT 1PHASE 600V 1.5A ABS
ABS15JHRGG 数据手册
ABS15J – ABS15M Taiwan Semiconductor 1.5A, 600V - 1000V Standard Bridge Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Glass passivated chip junction Ideal for automated placement Reliable low cost construction utilizing molded plastic technique High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 1.5 A VRRM 600 - 1000 V IFSM 40 A TJ MAX 150 °C Package ABS Configuration Quad APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● Lighting application MECHANICAL DATA ● ● ● ● ● ● Case: ABS Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 0.096g (approximately) ABS ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device ABS15J ABS15M ABS15J ABS15M UNIT Repetitive peak reverse voltage VRRM 600 1000 V Reverse voltage, total rms value VR(RMS) 420 700 V Forward current On glass-epoxy On aluminum substrate Surge peak forward current t = 8.3ms single half sinewave t = 1.0ms superimposed on rated load Rating for fusing (t
ABS15JHRGG 价格&库存
很抱歉,暂时无法提供与“ABS15JHRGG”相匹配的价格&库存,您可以联系我们找货
