MBS10HRCG
MBS10HRCG
    TAIWANSEMICONDUCTOR(台湾半导体)
    BESOP4
    BRIDGE RECT 1PHASE 1KV 500MA MBS
MBS10HRCG 数据手册
MBS2 – MBS10 Taiwan Semiconductor 0.8A, 200V - 1000V Standard Bridge Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Ideal for automated placement Reliable low cost construction utilizing molded plastic technique High surge current capability UL Recognized File # E-326854 Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 0.8 A VRRM 200 - 1000 V IFSM 35 A TJ MAX 150 °C Package TO-269AA (MBS) Configuration Quad APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● Lighting application MECHANICAL DATA ● ● ● ● ● ● Case: TO-269AA (MBS) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 0.120g (approximately) MBS ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device MBS2 MBS4 MBS6 MBS8 MBS10 UNIT MBS2 MBS4 MBS6 MBS8 MBS10 Repetitive peak reverse voltage VRRM 200 400 600 800 1000 V Reverse voltage, total rms value VR(RMS) 140 280 420 560 700 V Forward current On glass-epoxy On aluminum substrate Surge peak forward current, 8.3ms single half sine-wave superimposed on rated load 0.5 A 0.8 A IFSM 35 A IF Rating for fusing (t
MBS10HRCG 价格&库存
很抱歉,暂时无法提供与“MBS10HRCG”相匹配的价格&库存,您可以联系我们找货
