DBLS104GHRDG
DBLS104GHRDG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SMD4
    BRIDGE RECT 1PHASE 400V 1A DBLS
DBLS104GHRDG 数据手册
DBLS101G – DBLS107G Taiwan Semiconductor 1A, 50V - 1000V Standard Bridge Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Ideal for printed circuit board Reliable low cost construction utilizing molded plastic technique High surge current capability UL Recognized File # E-326854 Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 1 A VRRM 50 - 1000 V IFSM 30, 40 A TJ MAX 150 °C Package DBLS Configuration Quad APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● Lighting application MECHANICAL DATA ● ● ● ● ● ● Case: DBLS Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 0.360g (approximately) DBLS ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device Repetitive peak reverse voltage VRRM Reverse voltage, total rms value VR(RMS) Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Rating for fusing (t
DBLS104GHRDG
物料型号:DBLS101G至DBLS107G
器件简介:这些是1A电流,50V至1000V电压等级的标准桥式整流器,采用塑料封装技术,具有高浪涌电流承受能力,符合AEC-Q101标准,适用于印刷电路板。
引脚分配:文档中没有明确提供引脚分配图,但通常桥式整流器有四个引脚,分别为阳极、阴极和两个交流输入端。
参数特性: - 正向电流(IF):1A - 反向峰值重复电压(VRRM):50V至1000V - 正向浪涌电流(IFSM):30A或40A,具体取决于型号 - 最大结温(TJMAX):150°C
功能详解:文档提供了电气规格、热性能、订购信息、特性曲线和封装尺寸等详细信息。
应用信息:适用于开关电源(SMPS)、适配器、照明应用等。
封装信息:封装类型为DBLS,符合UL 94V-0可燃性等级,引脚为镀锡,可焊接。
DBLS104GHRDG 价格&库存
很抱歉,暂时无法提供与“DBLS104GHRDG”相匹配的价格&库存,您可以联系我们找货
