UR8KB100 C2G
UR8KB100 C2G
    TAIWANSEMICONDUCTOR(台湾半导体)
    SIP4
    BRIDGE RECT 1PHASE 1KV 8A D3K
UR8KB100 C2G 数据手册
UR8KB60 – UR8KB100 Taiwan Semiconductor 8A, 600V - 1000V Standard Bridge Rectifier FEATURES ● ● ● ● ● ● KEY PARAMETERS Ideal for printed circuit board High case dielectric strength High surge current capability UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 8 A VRRM 600 - 1000 V IFSM 170 A TJ MAX 150 °C APPLICATIONS ● Switching mode power supply ● Adapters ● Lighting application Package D3K Configuration Quad MECHANICAL DATA ● ● ● ● ● ● ● Case: D3K Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 1A whisker test Mounting torque: 0.80 N⋅m maximum Polarity: As marked Weight: 1.24g (approximately) D3K ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL UR8KB60 UR8KB80 UR8KB100 UNIT Marking code on the device UR8KB60 UR8KB80 UR8KB100 Repetitive peak reverse voltage VRRM 600 800 1000 V Reverse voltage, total rms value VR(RMS) 420 560 700 V Forward current Surge peak forward current, 8.3ms single half sine-wave superimposed on rated load Rating for fusing (t
UR8KB100 C2G 价格&库存
很抱歉,暂时无法提供与“UR8KB100 C2G”相匹配的价格&库存,您可以联系我们找货
