MBRF1635 – MBRF16150
Taiwan Semiconductor
16A, 35V - 150V Schottky Barrier Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Low power loss, high efficiency
Guard ring for over-voltage protection
High surge current capability
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
16
A
VRRM
35 - 150
V
IFSM
150
A
TJ MAX
150
°C
Package
ITO-220AC
Configuration
Single die
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converter
MECHANICAL DATA
Case: ITO-220AC
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.70g (approximately)
ITO-220AC
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
Repetitive peak revers voltage
Reverse voltage total
rms value
Forward current
Surge peak forward current,
8.3ms single half sine wave
superimposed on rated load
Peak repetitive reverse surge
(1)
current
Peak repetitive forward current
(Rated VR, Square wave, 20KHz)
Critical rate of rise of off-state
voltage
Junction temperature
Storage temperature
VRRM
VR(RMS)
MBRF MBRF MBRF MBRF MBRF
1635 1645 1650 1660 1690
1635
1645
1650
1660
1690
35
45
50
60
90
24
31
35
42
63
MBRF
16100
MBRF
16100
100
70
MBRF
UNIT
16150
MBRF
16150
150
V
105
V
IF
16
A
IFSM
150
A
IRRM
1.0
0.5
A
IFRM
32
A
dv/dt
10,000
V/µs
TJ
-55 to +150
°C
TSTG
-55 to +150
°C
Notes:
1. tp = 2.0μs, 1.0KHz
1
Version: K2105
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
3
°C/W
Junction-to-case resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
(2)
MBRF1635
MBRF1645
MBRF1650
MBRF1660
MBRF1690
MBRF16100
MBRF16150
MBRF1635
MBRF1645
MBRF1650
MBRF1660
MBRF1690
MBRF16100
MBRF16150
MBRF1635
MBRF1645
MBRF1650
MBRF1660
MBRF1690
MBRF16100
MBRF16150
MBRF1635
MBRF1645
MBRF1650
MBRF1660
MBRF1690
MBRF16100
MBRF16150
SYMBOL
IF = 16A, TJ = 25°C
VF
IF = 16A, TJ = 125°C
TYP
MAX
UNIT
0.63
V
0.75
V
0.85
V
0.95
V
0.57
V
0.65
V
0.75
V
0.92
V
500
µA
300
µA
100
µA
15
mA
10
mA
7.5
mA
5
mA
TJ = 25°C
IR
TJ = 125°C
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
MBRF16x
ITO-220AC
50 / Tube
MBRF16xH
ITO-220AC
50 / Tube
Notes:
1. “x” defines voltage from 35V(MBRF1635) to 150V(MBRF16150)
2. “H” means AEC-Q101 qualified
2
Version: K2105
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
16
CAPACITANCE (pF)
12
8
100
4
f=1.0MHz
Vsig=50mVp-p
10
50
75
100
125
0.1
150
1
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
MBRF1635-1645
MBRF1650-16150
1
TJ=125°C
0.1
0.01
TJ=25°C
0.001
10
40
50
60
70
80
100
Fig.4 Typical Forward Characteristics
100
90
100
100
10
1
10
UF1DLW
TJ=125°C
TJ=125°C
0.1
TJ=25°C
TJ=25°C
MBRF1635-1645
MBRF1650-1660
MBRF1690-16150
1
0.01
Pulse width
300μs
Pulse
width
1% duty cycle
0.001
0.1
0.4 0.3 0.5
0.60.6 0.7
0 0.3
0.1 0.2
0.4 0.5
0.7 0.80.80.9 0.9
1 1.1 11.2 1.1
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Fig.5 Maximum Non-Repetitive Forward Surge Current
180
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.3 Typical Reverse Characteristics
10
10
REVERSE VOLTAGE (V)
150
120
90
60
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
(A)
AVERAGE FORWARD CURRENT (A)
Version: K2105
1.2
Fig.6 Typical Transient Thermal Characteristics
TRANSIENT THERMAL IMPEDANCE (°C/W)
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
4
Version: K2105
PACKAGE OUTLINE DIMENSIONS
ITO-220AC
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: K2105
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: K2105
很抱歉,暂时无法提供与“MBRF1660 C0G”相匹配的价格&库存,您可以联系我们找货
