SRF2090 C0G
SRF2090 C0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-3
    DIODE ARRAY SCHOTT 90V ITO220AB
SRF2090 C0G 数据手册
SRF2020 – SRF20150 Taiwan Semiconductor 20A, 20V - 150V Schottky Barrier Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Low power loss, high efficiency Guard ring for overvoltage protection High surge current capability UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 20 A VRRM 20 - 150 V IFSM 200 A TJ MAX 125, 150 °C Package ITO-220AB Configuration Dual dies ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converters MECHANICAL DATA ● ● ● ● ● ● ● Case: ITO-220AB Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.70g (approximately) ITO-220AB ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature Storage temperature SRF SRF SRF SRF SRF SRF SRF SRF 2020 2030 2040 2050 2060 2090 20100 20150 SRF SRF SRF SRF SRF SRF SRF SRF 2020 2030 2040 2050 2060 2090 20100 20150 UNIT VRRM 20 30 40 50 60 90 100 150 V VR(RMS) 14 21 28 35 42 63 70 105 V IF 20 A IFSM 200 A TJ -55 to +125 TSTG -55 to +150 -55 to +150 1 °C °C Version: J2105 SRF2020 – SRF20150 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER Junction-to-case thermal resistance SYMBOL TYP UNIT RӨJC 1.5 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL TYP MAX UNIT - 0.55 V - 0.70 V - 0.92 V - 1.02 V - 500 µA - 100 µA - 15 mA - 10 mA - - mA - - mA - 5 mA SRF2020 SRF2030 SRF2040 Forward voltage per diode (1) SRF2050 SRF2060 IF = 10A,TJ = 25°C VF SRF2090 SRF20100 SRF20150 SRF2020 SRF2030 SRF2040 Reverse current @ rated VR per diode (2) SRF2050 SRF2060 TJ = 25°C IR SRF2090 SRF20100 SRF20150 SRF2020 SRF2030 SRF2040 Reverse current @ rated VR per diode (2) SRF2050 SRF2060 TJ = 100°C IR SRF2090 SRF20100 SRF20150 SRF2020 SRF2030 SRF2040 Reverse current @ rated VR per diode (2) SRF2050 SRF2060 TJ = 125°C IR SRF2090 SRF20100 SRF20150 Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms 2 Version: J2105 SRF2020 – SRF20150 Taiwan Semiconductor ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SRF20x ITO-220AB 50 / Tube SRF20xH ITO-220AB 50 / Tube Notes: 1. “x” defines voltage from 20V(SRF2020) to 150V(SRF20150) 2. “H” means AEC-Q101 qualified 3 Version: J2105 SRF2020 – SRF20150 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 SRF2060 - 20150 20 CAPACITANCE (pF) 15 10 SRF2020 - 2050 SRF2020-2040 1000 SRF2050-2060 100 SRF2090-20150 5 f=1.0MHz Vsig=50mVp-p 10 0 25 50 75 100 125 0.1 150 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=100°C 1 0.1 TJ=25°C 0.01 10 20 30 40 50 60 70 80 100 Fig.4 Typical Forward Characteristics 100 90 100 100 10 SRF2020-2040 10 UF1DLW 1 SRF2050-2060 TJ=125°C TJ=25°C 0.1 SRF20150 1 SRF2090-20100 0.01 0.1 0.001 0.0 0.3 0.2 0.4 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% duty cycle Pulse width 0.4 0.5 0.60.6 0.7 0.80.8 1.0 0.9 11.2 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 250 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.3 Typical Reverse Characteristics 10 10 REVERSE VOLTAGE (V) 8.3ms single half sine wave 200 150 100 50 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 4 (A) AVERAGE FORWARD CURRENT (A) 25 Version: J2105 1.2 SRF2020 – SRF20150 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Impedance TRANSIENT THERMAL IMPEDANCE (°C/W) 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 5 Version: J2105 SRF2020 – SRF20150 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS ITO-220AB MARKING DIAGRAM 6 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: J2105 SRF2020 – SRF20150 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 7 Version: J2105
SRF2090 C0G 价格&库存
很抱歉,暂时无法提供与“SRF2090 C0G”相匹配的价格&库存,您可以联系我们找货
