TBS406 M1G
TBS406 M1G
    TAIWANSEMICONDUCTOR(台湾半导体)
    SMD4
    TBS406 M1G
TBS406 M1G 数据手册
TBS406 – TBS410 Taiwan Semiconductor 4A, 600V - 1000V Standard Bridge Rectifier FEATURES ● ● ● ● ● ● KEY PARAMETERS Glass passivated chip junction Ideal for automated placement UL Recognized File # E-326854 Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● Lighting application PARAMETER VALUE UNIT IF 4 A VRRM 600 - 1000 V IFSM 110 A TJ MAX 150 °C Package TBS Configuration Quad MECHANICAL DATA ● ● ● ● ● ● Case: TBS Molding compound meets UL 94V-0 flammability rating Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 1 whisker test Polarity: As marked Weight: 0.220g (approximately) TBS ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device TBS406 TBS408 TBS410 TBS406 TBS408 TBS410 UNIT Repetitive peak reverse voltage VRRM 600 800 1000 V Reverse voltage, total rms value VR(RMS) 420 560 700 V Forward current Surge peak forward current single half sine-wave superimposed on rated load IF t = 8.3ms IFSM t = 1.0ms 4 A 110 A 340 A Rating for fusing (t
TBS406 M1G 价格&库存
很抱歉,暂时无法提供与“TBS406 M1G”相匹配的价格&库存,您可以联系我们找货
