ABS2 RGG
ABS2 RGG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SMD4
    BRIDGE RECT 1P 200V 800MA ABS
ABS2 RGG 数据手册
ABS2 – ABS10 Taiwan Semiconductor 1A, 200V- 1000V Standard Bridge Rectifier FEATURES ● ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Glass passivated chip junction Ideal for automated placement Reliable low cost construction utilizing molded plastic technique High surge current capability UL Recognized File # E-326854 Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 1 A VRRM 200 - 1000 V IFSM 30 A TJ MAX 150 °C Package ABS Configuration Quad APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● Lighting application MECHANICAL DATA ● ● ● ● ● ● Case: ABS Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 0.120g (approximately) ABS ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device ABS2 ABS4 ABS6 ABS8 ABS10 UNIT ABS2 ABS4 ABS6 ABS8 ABS10 Repetitive peak reverse voltage VRRM 200 400 600 800 1000 V Reverse voltage, total rms value VR(RMS) 140 280 420 560 700 V 0.8 A 1.0 A IFSM 30 A It 2 3.74 As Junction temperature TJ - 55 to +150 °C Storage temperature TSTG - 55 to +150 °C Forward current On glass-epoxy On aluminum substrate Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Rating for fusing (t
ABS2 RGG 价格&库存
很抱歉,暂时无法提供与“ABS2 RGG”相匹配的价格&库存,您可以联系我们找货
