GBPC15, 25, 35 SERIES
Taiwan Semiconductor
15A, 25A, 35A, 50V - 1000V Standard Bridge Rectifier
FEATURES
KEY PARAMETERS
● Glass passivated chip junction
● Integrally molded heatsink provide very low thermal resistance
for maximum heat dissipation
● Typical IR less than 0.2μA
● High surge current capability
● UL Recognized File # E-326243
● RoHS Compliant
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
15, 25, 35
A
VRRM
50 - 1000
V
IFSM
300, 400
A
TJ MAX
150
°C
Package
GBPC
Configuration
Quad
● Switching mode power supply (SMPS)
● AC to DC converter
MECHANICAL DATA
● Case: GBPC
GBPC-W: Wire structure
GBPC40-M: Terminal cathode parallel to anode
● Molding compound meets UL 94V-0 flammability rating
● Terminal: Matte tin plated leads, solderable per J-STD-002
● Meet JESD 201 class 1A whisker test
● Mounting torque: 20 in-lbs maximum
● Polarity: As marked
● Weight: 16.95g (approximately)
GBPC
GBPC-W
GBPC-M
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
005
01
02
04
06
08
10
UNIT
Repetitive peak reverse voltage
VRRM
50
100
200
400
600
800
1000
V
Reverse voltage, total rms value
VR(RMS)
35
70
140
280
420
560
700
V
GBPC15
Forward current
Peak forward surge current,
8.3ms single half sine-wave
superimposed on rated load
Rating for fusing (t
很抱歉,暂时无法提供与“GBPC2504 T0G”相匹配的价格&库存,您可以联系我们找货
