GBPC35005M T0G
GBPC35005M T0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    Square-4
    BRIDGE RECT 1P 50V 35A GBPC-M
GBPC35005M T0G 数据手册
GBPC15, 25, 35 SERIES Taiwan Semiconductor 15A, 25A, 35A, 50V - 1000V Standard Bridge Rectifier FEATURES KEY PARAMETERS ● Glass passivated chip junction ● Integrally molded heatsink provide very low thermal resistance for maximum heat dissipation ● Typical IR less than 0.2μA ● High surge current capability ● UL Recognized File # E-326243 ● RoHS Compliant APPLICATIONS PARAMETER VALUE UNIT IF 15, 25, 35 A VRRM 50 - 1000 V IFSM 300, 400 A TJ MAX 150 °C Package GBPC Configuration Quad ● Switching mode power supply (SMPS) ● AC to DC converter MECHANICAL DATA ● Case: GBPC GBPC-W: Wire structure GBPC40-M: Terminal cathode parallel to anode ● Molding compound meets UL 94V-0 flammability rating ● Terminal: Matte tin plated leads, solderable per J-STD-002 ● Meet JESD 201 class 1A whisker test ● Mounting torque: 20 in-lbs maximum ● Polarity: As marked ● Weight: 16.95g (approximately) GBPC GBPC-W GBPC-M ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL 005 01 02 04 06 08 10 UNIT Repetitive peak reverse voltage VRRM 50 100 200 400 600 800 1000 V Reverse voltage, total rms value VR(RMS) 35 70 140 280 420 560 700 V GBPC15 Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Rating for fusing (t
GBPC35005M T0G
物料型号:GBPC15, 25, 35系列
器件简介: - 这些是标准桥式整流器,具有15A、25A、35A的电流容量和50V至1000V的反向峰值电压。 - 特点包括玻璃钝化芯片结、整体模塑散热器、低热阻、高浪涌电流能力等。
引脚分配: - 引脚分配未在文档中明确说明,但通常桥式整流器有四个引脚,分别为两个阳极输入和两个阴极输出。
参数特性: - 正向电流(IF):15A、25A、35A - 反向峰值电压(VRRM):50V至1000V - 正向浪涌电流(IFSM):300A、400A - 最大结温(TJ MAX):150°C
功能详解: - 主要应用于开关电源(SMPS)和交流转直流转换器(AC to DC converter)。
应用信息: - 适用于开关模式电源供应和交流至直流转换器。
封装信息: - 封装类型:GBPC - 配置:四元组(Quad) - 重量:大约16.95克
GBPC35005M T0G 价格&库存
很抱歉,暂时无法提供与“GBPC35005M T0G”相匹配的价格&库存,您可以联系我们找货
