SR002 – SR010
Taiwan Semiconductor
0.5A, 20V - 100V Schottky Barrier Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Low forward voltage drop
Low power loss, high efficiency
Guard ring for overvoltage protection
High surge current capability
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
0.5
A
VRRM
20 - 100
V
IFSM
30
A
TJ MAX
125, 150
°C
APPLICATIONS
Package
DO-204AL (DO-41)
Configuration
Single die
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converter
MECHANICAL DATA
Case: DO-204AL (DO-41)
Molding compound meets UL 94V-0 flammability rating
Terminal: Pure tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.330g (approximately)
DO-204AL (DO-41)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Repetitive peak reverse voltage
VRRM
SR
002
SR
002
Reverse voltage, total rms value
VR(RMS)
14
PARAMETER
SYMBOL
Marking code on the device
SR
003
SR
003
30
SR
004
SR
004
40
SR
005
SR
005
50
SR
006
SR
006
60
SR
009
SR
009
90
21
28
35
42
63
SR
UNIT
010
SR
010
100
V
70
V
Forward current
Surge peak forward current, 8.3ms single
half sine wave superimposed on rated load
Junction temperature
IF
0.5
A
IFSM
30
A
Storage temperature
TSTG
TJ
-55 to +125
-55 to +150
-55 to +150
1
°C
°C
Version: H2104
SR002 – SR010
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJA
50
°C/W
Junction-to-ambient thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
(2)
Junction capacitance
SR002
SR003
SR004
SR005
SR006
SR009
SR010
SR002
SR003
SR004
SR006
SR009
SR010
SR002
SR003
SR004
SR005
SR006
SR009
SR010
SR002
SR003
SR004
SR005
SR006
SR009
SR010
SR002
SR003
SR004
SR005
SR006
SR009
SR010
IF = 0.5A, TJ = 25°C
SYMBOL
VF
TYP
MAX
UNIT
0.55
V
0.70
V
0.85
V
500
µA
100
µA
10
mA
5
mA
mA
mA
mA
2
mA
110
pF
80
pF
65
pF
TJ = 25°C
TJ = 100°C
IR
TJ = 125°C
1MHz, VR = 4.0V
CJ
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
SR0x
DO-204AL (DO-41)
5,000 / Tape & Reel
SR0x A0G
DO-204AL (DO-41)
3,000 / Ammo box
SR0xH
DO-204AL (DO-41)
5,000 / Tape & Reel
SR0xHA0G
DO-204AL (DO-41)
3,000 / Ammo box
Notes:
1. “x” defines voltage from 20V (SR002) to 100V (SR010)
2. “H” means AEC-Q101 qualified
2
Version: H2104
SR002 – SR010
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
CAPACITANCE (pF)
SR005 - SR010
0.5
SR002-SR004
100
SR005-SR010
10
SR002 - SR004
f=1.0MHz
Vsig=50mVp-p
1
25
50
75
100
125
150
0.1
1
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
TJ=75°C
0.01
TJ=25°C
0.001
10
40
50
60
70
80
90
100
10 10
SR002-SR004
UF1DLW
1
TJ=125°C
SR005-SR006 T =25°C
J
10.1
SR009-SR010
0.01
Pulse width 300μs
1% duty cycle
Pulse width
0.1
0.001
0.20.3 0.4 0.40.6 0.50.8 0.61.0 0.7
1.2 0.8
1.4 0.9
1.6
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
1.8
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
35
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
10
0.1
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
1
10
(A)
AVERAGE FORWARD CURRENT (A)
1
30
8.3ms single half sine wave
25
10
5
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: H2104
1.2
SR002 – SR010
Fig.6 Typical Transient Thermal Characteristics
TRANSIENT THERMAL IMPEDANCE (°C/W)
100
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
4
Version: H2104
SR002 – SR010
PACKAGE OUTLINE DIMENSIONS
DO-204AL (DO-41)
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: H2104
SR002 – SR010
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: H2104
很抱歉,暂时无法提供与“SR006 R1G”相匹配的价格&库存,您可以联系我们找货
