SF14GHB0G
SF14GHB0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-204AL
    DIODE GEN PURP 200V 1A DO204AL
SF14GHB0G 数据手册
SF11G – SF18G Taiwan Semiconductor 1A, 50V - 600V Super Fast Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Super Fast, low VF High current capability High reliability Low power loss RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 1 A VRRM 50 - 600 V IFSM 30 A TJ MAX 150 °C Package DO-204AL (DO-41) Configuration Single die ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● Case: DO-204AL (DO-41) Molding compound meets UL 94V-0 flammability rating Terminal: Pure tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.350g (approximately) DO-204AL (DO-41) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SF 11G SF 11G SF 12G SF 12G SF 13G SF 13G SF 14G SF 14G SF 15G SF 15G SF 16G SF 16G SF 17G SF 17G SF UNIT 18G SF 18G VRRM 50 100 150 200 300 400 500 600 V VR(RMS) 35 70 105 140 210 280 350 420 V SYMBOL Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature Storage temperature IF 1 A IFSM 30 A TJ -55 to +150 °C TSTG -55 to +150 °C 1 Version: H2104 SF11G – SF18G Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 20 °C/W Junction-to-ambient thermal resistance RӨJA 80 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS SF11G SF12G SF13G SF14G SF15G SF16G SF17G SF18G (1) Reverse current @ rated VR TJ = 25°C (2) Junction capacitance IF = 1A, TJ = 25°C Reverse recovery time 1MHz, VR = 4.0V IF = 0.5A, IR = 1.0A, Irr = 0.25A TYP MAX UNIT - 0.95 V - 1.30 V - 1.70 V - 5 µA - 100 µA 20 - pF 10 - pF - 35 ns VF IR TJ = 125°C SF11G SF12G SF13G SF14G SF15G SF16G SF17G SF18G SYMBOL CJ trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SF1xG DO-204AL (DO-41) 5,000 / Tape & Reel SF1xG A0G DO-204AL (DO-41) 3,000 / Ammo box SF1xGH DO-204AL (DO-41) 5,000 / Tape & Reel SF1xGHA0G DO-204AL (DO-41) 3,000 / Ammo box Notes: 1. “x” defines voltage from 50V (SF11G) to 600V (SF18G) 2. “H” means AEC-Q101 qualified 2 Version: H2104 SF11G – SF18G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 SF11G-14G CAPACITANCE (pF) 1 0 25 50 75 100 125 10 SF15G-18G f=1.0MHz Vsig=50mVp-p 1 150 0.1 1 AMBIENT TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 10 TJ=75°C 1 TJ=25°C 0.1 20 30 40 50 60 70 80 100 Fig.4 Typical Forward Characteristics 100 90 100 10 10 SF11G-14G UF1DLW 1 TJ=125°C TJ=25°C 10.1 SF15G-16G 0.01 SF17G-18G 0.1 0.001 0.5 0.7 0.9 1.1 0.3 0.4 0.5 0.6 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% duty cycle Pulse width 1.3 0.7 1.5 0.8 1.7 0.9 1.9 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 35 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (µA) Fig.3 Typical Reverse Characteristics 10 10 REVERSE VOLTAGE (V) (A) AVERAGE FORWARD CURRENT (A) 2 30 8.3ms single half sine wave 25 20 15 10 5 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: H2104 1.2 SF11G – SF18G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: H2104 SF11G – SF18G Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-204AL (DO-41) MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: H2104 SF11G – SF18G Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: H2104
SF14GHB0G
1. 物料型号:SF11G至SF18G,代表不同的反向重复峰值电压等级,从50V至600V。 2. 器件简介:这些超快速整流器具有超快响应、低正向电压、高电流承载能力、高可靠性、低功耗、符合RoHS标准和无卤素等特点。 3. 引脚分配:文档中提到了阳极和阴极的标记,但没有提供详细的引脚分配图。 4. 参数特性: - 正向电流(IF):1A - 反向重复峰值电压(VRRM):50V至600V - 浪涌正向电流(IFSM):某些型号可达30A - 最大结温(TJMAX):150°C 5. 功能详解:适用于DC-DC转换器、开关模式转换器和逆变器、以及自由轮应用。 6. 应用信息:文档提到了器件的应用领域,如DC-DC转换器等。 7. 封装信息:封装类型为DO-204AL (DO-41),符合UL 94V-0可燃性等级,终端为纯锡镀层引线。 8. 绝对最大额定值和热性能、电气规格:提供了详细的工作条件和性能参数。 9. 订购信息:提供了订购代码、封装和包装信息。 10. 特性曲线:包含了正向电流降额曲线、典型结电容、典型反向特性、典型正向特性和最大非重复性正向浪涌电流等图表。 11. 反向恢复时间特性和测试电路图:展示了测试设置和结果。 12. 封装外形尺寸:提供了DO-204AL (DO-41)封装的详细尺寸。 13. 标记图:说明了产品上的标记代码。
SF14GHB0G 价格&库存
很抱歉,暂时无法提供与“SF14GHB0G”相匹配的价格&库存,您可以联系我们找货
