MUR420 – MUR460
Taiwan Semiconductor
4A, 200V - 600V Ultra Fast Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Ultra fast recovery time for high efficiency
Excellent high temperature switching
Glass passivated chip junction
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
● DC to DC converter
● Switching mode converters and inverters
● Freewheeling application
PARAMETER
VALUE
UNIT
IF
4
A
VRRM
200 - 600
V
IFSM
125
A
TJ MAX
175
°C
Package
DO-201AD
Configuration
Single die
MECHANICAL DATA
Case: DO-201AD
Molding compound meets UL 94V-0 flammability rating
Terminal: Pure tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 1.20g (approximately)
DO-201AD
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL MUR420 MUR440 MUR460 UNIT
Marking code on the device
MUR420
MUR440
MUR460
Repetitive peak reverse voltage
VRRM
200
400
600
V
Reverse voltage, total rms value
VR(RMS)
140
280
420
V
Forward current
Surge peak forward current, 8.3ms single half sine
wave superimposed on rated load
Junction temperature
IF
4
A
IFSM
125
A
TJ
-55 to +175
°C
Storage temperature
TSTG
-55 to +175
°C
1
Version: J2105
MUR420 – MUR460
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
15
°C/W
Junction-to-ambient thermal resistance
RӨJA
28
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
(2)
MUR420
MUR440
MUR460
MUR420
MUR440
MUR460
MUR420
MUR440
MUR460
Junction capacitance
Reverse recovery time
MUR420
MUR440
MUR460
IF = 4A, TJ = 25°C
SYMBOL
VF
TJ = 25°C
IR
TJ = 125°C
1MHz, VR = 4.0V
CJ
IF = 0.5A, IR = 1.0A,
Irr = 0.25A
trr
TYP
MAX
UNIT
0.89
V
1.28
V
5
µA
10
µA
150
µA
250
µA
65
pF
25
ns
50
ns
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
MUR4x
DO-201AD
1,250 / Tape & Reel
MUR4x A0G
DO-201AD
500 / Ammo box
MUR4xH
DO-201AD
1,250 / Tape & Reel
MUR4xHA0G
DO-201AD
500 / Ammo box
Notes:
1. "x" defines voltage from 200V (MUR420) to 600V (MUR460)
2. “H” means AEC-Q101 qualified
2
Version: J2105
MUR420 – MUR460
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
4
CAPACITANCE (pF)
3
2
100
1
f=1.0MHz
Vsig=50mVp-p
25
50
75
100
125
150
175
0.1
1
AMBIENT TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=100°C
1
0.1
TJ=25°C
0.001
10
40
50
60
70
80
90
100
10 10
1
UF1DLW
MUR420
TJ=125°C
TJ=25°C
10.1
MUR440-60
0.01
0.1
0.001
0.3
0.5
0.3
0.4
Pulse width 300μs
1% duty cycle
Pulse width
0.7
0.5
0.9
0.6
1.1
1.3
1.5
0.7
0.8
0.9
1
1.1
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Fig.5 Maximum Non-Repetitive Forward Surge Current
150
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (µA)
Fig.4 Typical Forward Characteristics
100
0.01
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
10
10
(A)
AVERAGE FORWARD CURRENT (A)
5
125
100
75
50
25
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: J2105
1.2
MUR420 – MUR460
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: J2105
MUR420 – MUR460
PACKAGE OUTLINE DIMENSIONS
DO-201AD
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: J2105
MUR420 – MUR460
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: J2105
很抱歉,暂时无法提供与“MUR460 A0G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+8.912961+1.15303
- 10+5.5345810+0.71599
- 100+3.59977100+0.46569
- 国内价格 香港价格
- 500+2.75667500+0.35662
- 1000+2.489061000+0.32200
- 1500+2.352481500+0.30433
- 2500+2.199012500+0.28448
- 3500+2.108073500+0.27271
- 5000+2.019665000+0.26128
