ES3A – ES3J
Taiwan Semiconductor
3A, 50V - 600V Super Fast Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Glass passivated chip junction
Ideal for automated placement
Super fast recovery time for high efficiency
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
3
A
VRRM
50 - 600
V
IFSM
100
A
TJ MAX
150
°C
APPLICATIONS
● High frequency rectification
● Freewheeling application
● Switching mode converters and inverters in computer,
and telecommunication.
Package
DO-214AB (SMC)
Configuration
Single die
MECHANICAL DATA
Case: DO-214AB (SMC)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.210g (approximately)
DO-214AB (SMC)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL ES3A ES3B ES3C ES3D ES3F ES3G ES3H ES3J UNIT
Marking code on the device
Repetitive peak reverse voltage
VRRM
50
100
150
200
300
400
500
600
V
Reverse voltage, total rms value
VR(RMS)
35
70
105
140
210
280
350
420
V
Forward current
Peak forward surge current,
8.3ms single half sine-wave
superimposed on rated load
Junction temperature
IF
3
A
IFSM
100
A
TJ
- 55 to +150
°C
Storage temperature
TSTG
- 55 to +150
°C
1
Version: N2102
ES3A – ES3J
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
12
°C/W
Junction-to-ambient thermal resistance
RӨJA
47
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
ES3A
ES3B
ES3C
ES3D
ES3F
ES3G
ES3H
ES3J
(1)
Reverse current @ rated VR
TJ = 25°C
(2)
Junction capacitance
IF = 3A, TJ = 25°C
Reverse recovery time
1MHz, VR = 4.0V
IF = 0.5A, IR = 1.0A,
Irr = 0.25A
TYP
MAX
UNIT
0.95
V
1.30
V
1.70
V
10
µA
500
µA
45
pF
30
pF
35
ns
VF
IR
TJ = 100°C
ES3A
ES3B
ES3C
ES3D
ES3F
ES3G
ES3H
ES3J
SYMBOL
CJ
trr
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
ES3x
DO-214AB (SMC)
3,000 / Tape & Reel
Notes:
1. “x” defines voltage from 50V(ES3A) to 600V(ES3J)
2
Version: N2102
ES3A – ES3J
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
90
75
3
CAPACITANCE (pF)
2
1
60
45
ES3A - ES3D
30
ES3F - ES3J
15
f=1.0MHz
Vsig=50mVp-p
50
75
100
125
150
1
10
LEAD TEMPERATURE (°C)
REVERSE VOLTAGE (V)
Fig.4 Typical Forward Characteristics
INSTANTANEOUS FORWARD CURRENT (A)
1000
100
TJ=125°C
10
TJ=75°C
1
TJ=25°C
0.1
40
50
60
70
80
90
100
1010
ES3F - ES3G
UF1DLW
1 ES3A - ES3D
TJ=125°C
1
0.1
TJ=25°C
ES3H - ES3J
0.01
0.1
0.001
0.4
0.6
0.8
1.0
0.3
0.4
0.5
0.6
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Pulse width 300μs
1% duty cycle
Pulse width
1.2
0.7
1.4
0.8
1.6
0.9
1.8
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
110
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.3 Typical Reverse Characteristics
10
100
(A)
AVERAGE FORWARD CURRENT (A)
4
100
8.3ms single half sine wave
90
80
70
60
50
40
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: N2102
1.2
ES3A – ES3J
Fig.6 Typical Transient Thermal Impedance
TRANSIENT THERMAL IMPEDANCE (°C/W)
100
10
1
0.01
0.1
1
10
100
PULSE DURATION (s)
Fig.7 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: N2102
ES3A – ES3J
PACKAGE OUTLINE DIMENSIONS
DO-214AB (SMC)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: N2102
ES3A – ES3J
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: N2102
很抱歉,暂时无法提供与“ES3A R7G”相匹配的价格&库存,您可以联系我们找货
